[mapguide-users] Tool tips and Labeling
Johann Muller
johannfm at gmail.com
Fri Aug 25 02:35:04 EDT 2006
That is strange, here is one that i just tried. The " symbols are just
there because there is spaces in the filename.
/C:\street_data>shp2pgsql "Street 5m Buffer.shp" buffer > buffer.sql
Shapefile type: Polygon
Postgis type: MULTIPOLYGON[2]
Then the beginning of my buffer.sql:
BEGIN;
CREATE TABLE "buffer" (gid serial PRIMARY KEY,
"prefix" varchar(2),
"name" varchar(50),
"type" varchar(15),
"suffix" varchar(2),
"full_name" varchar(50),
"alt_name" varchar(50),
"label" varchar(50),
"route" varchar(30),
"roadclass" varchar(10),
"category" varchar(20),
"province" varchar(30),
"municipal" varchar(50),
"cityname" varchar(30),
"oldcity" varchar(35),
"sub_left" varchar(35),
"sub_right" varchar(35),
"f_zlev" int2,
"t_zlev" int2,
"oneway" varchar(2),
"ramp_flag" varchar(1),
"br_flag" varchar(1),
"tn_flag" varchar(1),
"meters" numeric,
"speed_lim" int2);
SELECT AddGeometryColumn('','buffer','the_geom','-1','MULTIPOLYGON',2);/
Once you have the buffer.sql you need to run this script on your
database to import the data.
The usage of the sh2sqlpgsql is as follows
shp2pgsql shape_file table_name > output_sql_file
Maybe try the following:
*shp2pgsql D:\roads.shp roads > d:\roads.sql
***Then go to the D: drive and the contents of the file roads.sql
Hope this helps.
//sukalyan chakraborty wrote:
> roads.sql is blank after running this .
> and it is running if i provide the commnd
> *shp2pgsql D:\roads.shp roads.sql *
> then postgre running the command and showing the extraction data from
> shp file but
> i'm sorry to say u that after that also the roads.sql file is blank.
> i'm also unable to see the database from postgre database window.
> On 8/25/06, *Johann Muller* <johannfm at gmail.com
> <mailto:johannfm at gmail.com>> wrote:
> Is there any errors that occur when you run the command?
> And what is the contents of *roads.sql *after you have run the
> command?
>> thanks a lot i've started my jouney on Shortest path
>> calculation.. at the path of my journey
>> i'm facing problem on *shp2pgsql D:\roads.shp roads > roads.sql
>> *to convert the sql file into postgreSQL 8 format. it is not
>> converting. Is there any help with anybody??
>> On 8/19/06, *Jason Birch* <Jason.Birch at nanaimo.ca
>> <mailto:Jason.Birch at nanaimo.ca>> wrote:
>> There is no direct routing (or geocoding) capability in
>> MapGuide. However you could implement this at the database
>> level. Here's a link that might help:
>> http://chris.narx.net/2005/12/14/build-your-own-routing-solution/
>> I'm not sure if this will work with the OGR provider for
>> PostGIS.
>> I guess you could set up a table that contains a cross
>> product of all the nodes, along with the routes between them
>> and the relative costs. This could get very, very large though.
>> Also, you'd have to build some logic to extract the portions
>> of the lines between the start/destination points on the line
>> and the nodes at the start/end of the shortest route.
>> You'd probably want to use a few different weighting
>> mechanisms too: distance, speed, fewest left turns, etc.
>> This feature isn't of huge use to me, but I think it should
>> be high on the wishlist.
>> Jason
>> ________________________________
>> From: sukalyan chakraborty [mailto:
>> chakraborty.sarkar at gmail.com
>> <mailto:chakraborty.sarkar at gmail.com>]
>> Sent: Fri 2006-08-18 11:28 PM
>> To: users at mapguide.osgeo.org <mailto:users at mapguide.osgeo.org>
>> Subject: Re: [mapguide-users] Tool tips and Labeling
>> Thanks a lot i've solved my problem
>> Now can any body help me how can i implement a routing
>> algorithm on mapguide to find
>> the shortest path and as well as all posible path.
>> Is there any help or link available.
>> Thanks A Lot
>> Have A Nice Time
>> Have Fun
>> Be Jolly
>> Sukalyan Chakraborty
>> [Software Developer]
>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>> <mailto:users-unsubscribe at mapguide.osgeo.org>
>> For additional commands, e-mail:
>> users-help at mapguide.osgeo.org
>> <mailto:users-help at mapguide.osgeo.org>
>> Thanks A Lot
>> Have A Nice Time
>> Have Fun
>> Be Jolly
> Thanks A Lot
> Have A Nice Time
> Have Fun
> Be Jolly
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060825/98555b96/attachment.html
More information about the Mapguide-users
