[mapguide-users] Tool tips and Labeling
sukalyan chakraborty
chakraborty.sarkar at gmail.com
Fri Aug 25 08:13:07 EDT 2006
*Yehhhh.... *
thanks a lot... Johann
I got the sql file with the write sql string.
But now when i going to import the data into postgresql database
using
*psql -d my_db -f country.sql*
it wants the password:
i gave the password for the user postgres ;
password is sukalyan.
but it returns
psql: FATAL: password authentication failed for user "Administrator"
I've not yet any password for Administrator.
is there any default password for Administrator??
One more problem is i can not connect the server using pgadminIII
On 8/25/06, Johann Muller <johannfm at gmail.com> wrote:
> That is strange, here is one that i just tried. The " symbols are just
> there because there is spaces in the filename.
> *C:\street_data>shp2pgsql "Street 5m Buffer.shp" buffer > buffer.sql
> Shapefile type: Polygon
> Postgis type: MULTIPOLYGON[2]
> Then the beginning of my buffer.sql:
> BEGIN;
> CREATE TABLE "buffer" (gid serial PRIMARY KEY,
> "prefix" varchar(2),
> "name" varchar(50),
> "type" varchar(15),
> "suffix" varchar(2),
> "full_name" varchar(50),
> "alt_name" varchar(50),
> "label" varchar(50),
> "route" varchar(30),
> "roadclass" varchar(10),
> "category" varchar(20),
> "province" varchar(30),
> "municipal" varchar(50),
> "cityname" varchar(30),
> "oldcity" varchar(35),
> "sub_left" varchar(35),
> "sub_right" varchar(35),
> "f_zlev" int2,
> "t_zlev" int2,
> "oneway" varchar(2),
> "ramp_flag" varchar(1),
> "br_flag" varchar(1),
> "tn_flag" varchar(1),
> "meters" numeric,
> "speed_lim" int2);
> SELECT AddGeometryColumn('','buffer','the_geom','-1','MULTIPOLYGON',2);*
> Once you have the buffer.sql you need to run this script on your database
> to import the data.
> The usage of the sh2sqlpgsql is as follows
> shp2pgsql shape_file table_name > output_sql_file
> Maybe try the following:
> *shp2pgsql D:\roads.shp roads > d:\roads.sql
> ***Then go to the D: drive and the contents of the file roads.sql
> Hope this helps.
> **sukalyan chakraborty wrote:
> roads.sql is blank after running this .
> and it is running if i provide the commnd
> *shp2pgsql D:\roads.shp roads.sql *
> then postgre running the command and showing the extraction data from shp
> file but
> i'm sorry to say u that after that also the roads.sql file is blank.
> i'm also unable to see the database from postgre database window.
> > Is there any errors that occur when you run the command?
> > And what is the contents of *roads.sql *after you have run the command?
> > thanks a lot i've started my jouney on Shortest path calculation.. at
> > the path of my journey
> > i'm facing problem on *shp2pgsql D:\roads.shp roads > roads.sql *to
> > convert the sql file into postgreSQL 8 format. it is not converting. Is
> > there any help with anybody??
> > On 8/19/06, Jason Birch <Jason.Birch at nanaimo.ca > wrote:
> > > There is no direct routing (or geocoding) capability in
> > > MapGuide. However you could implement this at the database level. Here's a
> > > link that might help:
> > > http://chris.narx.net/2005/12/14/build-your-own-routing-solution/
> > > I'm not sure if this will work with the OGR provider for PostGIS.
> > > I guess you could set up a table that contains a cross product of all
> > > the nodes, along with the routes between them and the relative costs. This
> > > could get very, very large though.
> > > Also, you'd have to build some logic to extract the portions of the
> > > lines between the start/destination points on the line and the nodes at the
> > > start/end of the shortest route.
> > > You'd probably want to use a few different weighting mechanisms
> > > too: distance, speed, fewest left turns, etc.
> > > This feature isn't of huge use to me, but I think it should be high on
> > > the wishlist.
> > > Jason
> > > ________________________________
> > > From: sukalyan chakraborty [mailto: chakraborty.sarkar at gmail.com]
> > > Sent: Fri 2006-08-18 11:28 PM
> > > To: users at mapguide.osgeo.org
> > > Subject: Re: [mapguide-users] Tool tips and Labeling
> > > Thanks a lot i've solved my problem
> > > Now can any body help me how can i implement a routing algorithm
> > > on mapguide to find
> > > the shortest path and as well as all posible path.
> > > Is there any help or link available.
> > > Thanks A Lot
> > > Have A Nice Time
> > > Have Fun
> > > Be Jolly
> > > Sukalyan Chakraborty
> > > [Software Developer]
> > > To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> > > For additional commands, e-mail: users-help at mapguide.osgeo.org
> > Thanks A Lot
> > Have A Nice Time
> > Have Fun
> > Be Jolly
> Thanks A Lot
> Have A Nice Time
> Have Fun
> Be Jolly
Thanks A Lot
Have A Nice Time
Have Fun
Be Jolly
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060825/37ad0e60/attachment.html
More information about the Mapguide-users
