mapguide open source - no jsp
Axel Gross axel.gross at iaeste.at
Fri Aug 25 13:10:44 EDT 2006
Hi, this my second try at the list!
Meanwhile I tried to reinstall mapguide open source, but to no avail.
So I hope somebody will help me or tell me, if the jsp part is supposed to
work.
<snip>
I got a problem getting started with mapguide.
I tried to run the sample application for jsp, but
 http://localhost:8008/mapguide/javaviewersample/ajaxtiledviewersample.jsp
gives just plain jsp source back instead of processing.
Also
+http://localhost:8008/mapguide/mapviewerjava/ajaxviewer.jsp?WEBLAYOUT=Library%3a%2f%2fSamples%2fSheboygan%2fLayouts%2fShebo
+yganJsp.WebLayout
doesn't work completely as expected. In the right frame the task jsp also
are not rendered.
Jsp in general seems to work though, as the ajaxviewer.jsp response is okay.
hope you can help me getting it started.
</snip>
thanks,
Axel Groß
More information about the Mapguide-users mailing list
