[mapguide-users] mapguide open source - no jsp
Scott Reisdorf reisdorf1 at llnl.gov
Fri Aug 25 13:59:03 EDT 2006
You need to configure your Apache Web Server to direct the jsp pages to
the Tomcat Servlet engine.
In the httpd.conf  (MapGuideOpenSource\WebServerExtensions\Apache2\conf\
) make sure you direct the pages to Tomcat.
See page 24 of the Install guide:
https://mapguide.osgeo.org/files/documents/12/238/BuildConfigureMgOpenSourceOnWindows.pdf
-scott
Axel Gross wrote:
> Hi, this my second try at the list!
> Meanwhile I tried to reinstall mapguide open source, but to no avail.
> So I hope somebody will help me or tell me, if the jsp part is supposed to
> work.
> <snip>
> I got a problem getting started with mapguide.
> I tried to run the sample application for jsp, but
>  http://localhost:8008/mapguide/javaviewersample/ajaxtiledviewersample.jsp
> gives just plain jsp source back instead of processing.
> Also
> +http://localhost:8008/mapguide/mapviewerjava/ajaxviewer.jsp?WEBLAYOUT=Library%3a%2f%2fSamples%2fSheboygan%2fLayouts%2fShebo
> +yganJsp.WebLayout
> doesn't work completely as expected. In the right frame the task jsp also
> are not rendered.
> Jsp in general seems to work though, as the ajaxviewer.jsp response is okay.
> hope you can help me getting it started.
> </snip>
> thanks,
> Axel Groß
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
