[mapguide-users] BC Albers Projection not available
Paul Ramsey pramsey at refractions.net
Fri Aug 25 17:28:27 EDT 2006
Brad,
Sorry, I don't know the details, I am just reasoning by inference:
- MapGuide OS uses Proj4 as the reprojection engine
- Proj4 includes an epsg file of commonly known projections
- "init=epsg:3005" is a Proj4 string that will instantiate the BC
Albers projection
So I assume it's possible... :) but I don't know *how*.
P
On 25-Aug-06, at 2:14 PM, BradM wrote:
> Hi Paul,  how do we select epsg:3005 as the default projection?
> Paul Ramsey wrote:
>> In the open source version, epsg:3005 should map to BC Albers...
>> On 25-Aug-06, at 7:58 AM, BradM wrote:
>>> In British Columbia, Canada we use the BC Albers Projection.  This
>>> projection
>>> is not available in both Mapguide Enterprise and the open source
>>> version so
>>> we are unable to use our extensive base maps and orthophotos.  Does
>>> anyone
>>> know how to make the BC albers projection available with mapguide
>>> enterprise
>>> or the open source version?  thanks
>>> View this message in context: http://www.nabble.com/BC-Albers-
>>> Projection-not-available-tf2165226.html#a5985137
>>> Sent from the OSGeo MapGuide forum at Nabble.com.
>>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>> For additional commands, e-mail: users-help at mapguide.osgeo.org
> Projection-not-available-tf2165226.html#a5991428
More information about the Mapguide-users mailing list
