[mapguide-users] Newline characters not recognised in DWF viewer.
Walt Welton-Lair
walt.welton-lair at autodesk.com
Fri Dec 1 05:40:42 EST 2006
What version of MapGuide are you running? Are you building it yourself?
We just added multi-line label support to the AJAX viewer a few weeks
ago, and it will be in the next release.
Unless you're building MG yourself there's currently no way to make it
work with both viewers. With the next release though any of the
following will be interpreted as a line-break:
"\n" (char 92 + char 110)
\n\r (char 13 + char 10)
\r\n (char 10 + char 13)
\n (char 13)
\r (char 10)
So pick your favorite and just use that for now.
Walt
_____
From: Jackie Ng [mailto:jackie.ng at aecsystems.com.au]
Sent: Friday, December 01, 2006 5:20 AM
Subject: Re: [mapguide-users] Newline characters not recognised in DWF
viewer.
I've just tried this and yes it now works for the DWF viewer. But now,
the situation has reversed. The AJAX viewer now treats it as the string
"\n" instead of the control character.
Is there a solution that can work with both viewers?
Regards,
Jackie Ng
AEC Spatial Pty Ltd. / AEC Systems Pty Ltd.
SYDNEY - MELBOURNE - BRISBANE - PERTH - ADELAIDE - HOBART
A.B.N: 32 075 809 451
Level 4, 37-41 Prospect St. Box Hill, Victoria, 3128
Phone: 1300 368 609
Fax: 1300 362 140
www.aecsystems.com.au
Content-Type: multipart/alternative;
boundary="----_=_NextPart_001_01C714F0.434ACB9A"
Date: Thu, 30 Nov 2006 21:27:35 -0500
From: Walt Welton-Lair <walt.welton-lair at autodesk.com>
Subject: [mapguide-users] Newline characters not recognised in DWF
viewer.
Use "\n" (2 characters) in your label string, not '\n' (the control
character).
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061201/62b759c8/attachment.html
More information about the Mapguide-users
