[mapguide-users] Map guide stress testing
Traian Stanev
traian.stanev at autodesk.com
Mon Dec 11 11:56:05 EST 2006
For a fun way to do it... I have used the attached (rather sadistic)
script in the past. It does many many GetMapImage requests.
You will need to customize it with the bounds/center/scale of a map
definition of your choice. Then open it in Firefox and watch it churn.
For maximum pain you can go to "about:config" in Firefox and boost the
number of simultaneous http connections allowed. Then it should be
requesting multiple GetMapImages in parallel. The cool part is that the
returned images will get displayed and tiled correctly in the browser.
Traian
-----Original Message-----
Sent: Monday, December 11, 2006 5:04 AM
Subject: [mapguide-users] Map guide stress testing
Hi all,
I was wondering, is there a way to perform a stress test to mapguide
access?
as I need to know whether mapguide is capable to handle hundreds or
maybe thousands user access or not.
the main thing is i need to know the maximum access capacity that can be
handle by mapguide.
Any idea of this issue?
Thank you
Regards,
Kencana
View this message in context:
http://www.nabble.com/Map-guide-stress-testing-tf2792981.html#a7792120
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061211/75af56f3/getmaptest2.html
More information about the Mapguide-users
