[mapguide-users] RE: Session has expired or is invalid. Please log in again.
Ivan Miličević
ivan at prior.hr
Fri Dec 15 11:32:07 EST 2006
kreten
-----Original Message-----
Sent: 14. prosinac 2006 20:04
Subject: [mapguide-users] RE: Session has expired or is invalid. Please log
in again.
It works!!!
Thanks to you, Willem!
Willem Schwarte wrote:
> Check your index file where you open the weblayout. You should set the URL
> to http://www.mydomain.com/mapguide/ instead of http://localhost/
> Willem
> ________________________________
> Van: Ivan Miličević [mailto:ivan at ineo.hr]
> Verzonden: maandag 11 december 2006 12:15
> Aan: users at mapguide.osgeo.org
> Onderwerp: RE: [mapguide-users] Session has expired or is invalid. Please
> log in again.
> If the repository was copied across this would include the "Session"
> repository which would no longer be valid because it is cleared every time
> the server is restarted.
> Is Ivan storing information in the "Session" repository that he wants to
> persist? If so he needs to move it to the "Library" repository.
> Bruce
> From: Ivan Miličević [mailto:ivan at ineo.hr]
> Sent: 11. prosinac 2006 12:00
> Subject: RE: [mapguide-users] Session has expired or is invalid. Please
> log in again.
> Tražio sam mail ali nnisam mogao naći. Naći ću ja to sutra, sad mi vrijeme
> curi
> From: kruno at ineo.hr [mailto:kruno at ineo.hr]
> Sent: 7. prosinac 2006 17:16
> Subject: [mapguide-users] Session has expired or is invalid. Please log in
> again.
> Hi,
> i have a problem with the following error message:
> Session has expired or is invalid. Please log in again. Exception occurred
> in method MgSessionCache.GetSessionInfo at line 157 in file
c:\build_tux_area\mgdev_opensource\server\src\common\manager\SessionCache.cp
p
> This error appears only when I try to navigate to the map from www (e.g.
> www.mydomain.com/mapguide/mymap.aspx), i.e. everything works fine when I
> run this site locally (e.g. http://localhost/mapguide/mymap.aspx).
> Please help.
> Thanks,
> Kruno.
View this message in context:
http://www.nabble.com/Session-has-expired-or-is-invalid.-Please-log-in-again
.-tf2775505.html#a7878966
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users
