installing to a different drive...
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Wed Jul 5 09:19:46 EDT 2006
For the record, installing to a drive other than C or in another folder
other than Program Files doesn't work. You have to manually move files
(because it still installs a few files under C, even if you tell it not
to)...you also have to fix the 'automatic' IIS configuration, because it
too assumes that you installed it in c:\program files....and you have to
modify the webconfig.ini and php.ini...bascially, you have to manually
install the thing.
Andrew
*Andrew DeMerchant*
*Computer Technologist*
ph.1-877-4GEMTEC x.163
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
Fredericton, NB, Canada
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide-users
