[mapguide-users] I can't see views when I use the FDO/ODBC.
Andy Morsell amorsell at spatialgis.com
Thu Jul 6 00:24:18 EDT 2006
I switched my nomenclature around, they are Queries in Access and Views in
Oracle and SQL Server.  It would be nice if even Microsoft called them the
same thing between their different database programs..........
Andy
-----Original Message-----
From: Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
Sent: Wednesday, July 05, 2006 7:41 PM
Subject: Re: [mapguide-users] I can't see views when I use the FDO/ODBC.
Ah....I've never heard it called a View before.
Andy Morsell wrote:
> A view is a query definition within the Access database itself.  There
> are several types of views, but in this case, it would be a select
> view where either a single table is filtered or two or more tables are
> joined on a common key.  Views are very common.  They are called
> Queries in SQL Server and Views in Oracle.
> Andy
> Sent: Wednesday, July 05, 2006 2:47 PM
> What exactly are you trying to look for other than a table? What's a
'view'?
> Do you mean a 'form'? ODBC connections will only let you access
> tables. No forms, no reports, etc....
> Andrew
> Luiz Marcio Viana wrote:
>> Hi,
>> I'm trying to see views in MapGuide Studio, using the FDO/ODBC, but I
>> see only the tables.
>> I'm using the MS Access database and the last versions of MapGuide
>> Open Source and MapGuide Studio Preview.
>> Are there any problem with FDO/ODBC to publish views?
>> I know FDO/ODBC works only with MS Access. Is It right?
>> Thanks,
>> Luiz Marcio
>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
