[mapguide-users] I can't see views when I use the FDO/ODBC.
Luiz Marcio Viana
lmarcio at parsrio.com.br
Thu Jul 6 08:03:37 EDT 2006
...'Views' are the same than 'Queries' in MSAccess.
MapGuide 6.5 can use Views/Queries to represent Point Geometry or a
Secundary Table,
but I can't do it with MapGuide Open Source and FDO/ODBC.
I think this is a limitation of open source version. Is it right?
Does this problem occour with the new MapGuide Enterprise?
Thanks,
Luiz Marcio
----- Original Message -----
To: <users at mapguide.osgeo.org>
Sent: Thursday, July 06, 2006 1:24 AM
Subject: RE: [mapguide-users] I can't see views when I use the FDO/ODBC.
>I switched my nomenclature around, they are Queries in Access and Views in
> Oracle and SQL Server. It would be nice if even Microsoft called them the
> same thing between their different database programs..........
> Andy
> -----Original Message-----
> From: Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
> Sent: Wednesday, July 05, 2006 7:41 PM
> To: users at mapguide.osgeo.org
> Subject: Re: [mapguide-users] I can't see views when I use the FDO/ODBC.
> Ah....I've never heard it called a View before.
> Andy Morsell wrote:
>> A view is a query definition within the Access database itself. There
>> are several types of views, but in this case, it would be a select
>> view where either a single table is filtered or two or more tables are
>> joined on a common key. Views are very common. They are called
>> Queries in SQL Server and Views in Oracle.
>> Andy
>> Sent: Wednesday, July 05, 2006 2:47 PM
>> What exactly are you trying to look for other than a table? What's a
> 'view'?
>> Do you mean a 'form'? ODBC connections will only let you access
>> tables. No forms, no reports, etc....
>> Andrew
>> Luiz Marcio Viana wrote:
>>> Hi,
>>> I'm trying to see views in MapGuide Studio, using the FDO/ODBC, but I
>>> see only the tables.
>>> I'm using the MS Access database and the last versions of MapGuide
>>> Open Source and MapGuide Studio Preview.
>>> Are there any problem with FDO/ODBC to publish views?
>>> I know FDO/ODBC works only with MS Access. Is It right?
>>> Thanks,
>>> Luiz Marcio
>>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users
