[mapguide-users] RE: RE: Now a new problem - ODBC connection error
Andrew DeMerchant andrew.demerchant at gemtec.ca
Fri Jul 7 15:57:27 EDT 2006
It's going to be case-sensitive......My guess is your field name. That
ODBC provider (and Studio) doesn't like spaces much. For fun, try making
a field name without spaces and see if "get" works then....
simflex wrote:
>>>Well, a simple work-around would be to not press the 'get' button and just
>type in your value
>That was actually the initial approach I used.
>the fieldname="the first value"
>I kept doing it till all is done.
>When I refreshed the map, I don't see the symbols representing each value on
>the layer.
>So, when I went back to verify that everything was done correctly, I got the
>following error:
>"This filter contains the following advanced element(s)
>the named property is not available in this layer:
>myplace:
>Cannot leave advance mode until the expression is corrected"
>BTW: myplace is a field name with several different values.
>I use star as symbol with different colors to depict different value.
>I then decided to use the "Get from" method which resulted in the error I
>posted earlier.
	*Andrew DeMerchant*
*Computer Technologist*
ph.1-877-4GEMTEC x.163
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
Fredericton, NB, Canada
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide-users mailing list
