[mapguide-users] OBDC - testing connection
Ivan Miličević ivan at ineo.hr
Fri Jul 14 11:48:24 EDT 2006
I'll try that.
Thank you!
  _____
From: Robert Fortin [mailto:robert.fortin at autodesk.com]
Sent: 14. srpanj 2006 17:43
Subject: RE: [mapguide-users] OBDC - testing connection
Ivan,
One developer suggested to alter the config to use comma instead of dot.
like the following:
    <gml:boundingBox>
         <gml:pos>1234567,000000 1234567,000000</gml:pos>
      </gml:boundingBox>
The failure seems to occur somewhere in the code parsing that info and it
gets one parameters when it should see 2. It might related to your language
setup.
RF
  _____
Sent: Friday, July 14, 2006 11:39 AM
Ok,
Thanks!
  _____
From: Dave Wilson [mailto:dave.wilson at autodesk.com]
Sent: 14. srpanj 2006 17:37
And I'm not in a position to do that either. Maybe someone else on the list
has done a recent compile for Windows and can provide a link.
Sorry,
Dave
  _____
Sent: Friday, July 14, 2006 9:32 AM
Hi Dave,
It would be possible but i can't compile source code, don't ask why, simply
i can't. Could you do that for me? Please. Just send me a link and i will
reisntall or unistall server.
Thanx a lot!
Ivan
  _____
Sent: 14. srpanj 2006 17:24
I can't seem to find anything wrong with the config information when I
compare it to a working instance I have.
I suspect this is an issue with the 168.02 version. We did have some
problems that were fixed in regards to ODBC after that build. Would it be
possible to try this with a build of the current source?
Dave
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060714/11c99d70/attachment.html
More information about the Mapguide-users mailing list
