[mapguide-users] The "ideal" MapGuide server?
Marcus Spurkel
mspurkel at pacbell.net
Wed Jul 19 16:31:01 EDT 2006
Cool, thanks! Any reason to prefer or avoid a specific Linux distro?
I'm trying right now with FC5 but wouldn't mind switching if another is
more advantageous. What about Ubuntu or SuSE? RedHat ES, if it's worth
it, but something free would obviously be better.
-Marcus
Traian Stanev wrote:
>Hi Marcus,
>MapGuide doesn't yet compile on 64 bit platforms, so 64 bit is not an
>option for now.
>The amount of RAM needed would probably depend on how many simultaneous
>users you need to support. On a Linux box even 1 gig would work if you
>are not loading it up with too many complex requests.
>I can also imagine that certain custom written php scripts might
>exercise the mapguide API in ways that can use arbitrary amounts of
>memory, but that depends on you really. Also, I have seen some raster
>layers spike the memory usage significantly, so that's also a factor.
>Traian
>-----Original Message-----
>From: Marcus Spurkel [mailto:mspurkel at pacbell.net]
>Sent: Wednesday, July 19, 2006 2:51 AM
>To: users at mapguide.osgeo.org
>Subject: [mapguide-users] The "ideal" MapGuide server?
>I was wondering if there was any consensus out there as to what the
>ideal MapGuide server should consist of. I know you can have portions
>on separate machines but if it all needed to live on one box, what would
>the spec look like?
>1. Is a 64-bit CPU (and a 64-bit Linux distro) desirable? Can MapGuide
>even take advantage of 64-bit architecture?
>2. How much RAM? 1GB? 2? 4? Is it the more the better? How much swap
>space?
>3. Any specific mobos or other hardware to avoid?
>Any input would be greatly appreciated.
>-Marcus
>To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users
