[mapguide-users] The "ideal" MapGuide server?
    Willem Schwarte
    willem at giskit.nl
    Wed Jul 19 14:26:24 EDT 2006
Kijk Emil... Dat bedoel ik nou met onzin vertellen als iets niet lukt...
Willem
-----Oorspronkelijk bericht-----
Van: Traian Stanev [mailto:traian.stanev at autodesk.com]
Verzonden: woensdag 19 juli 2006 18:51
Aan: users at mapguide.osgeo.org
Onderwerp: RE: [mapguide-users] The "ideal" MapGuide server?
Hi Marcus,
MapGuide doesn't yet compile on 64 bit platforms, so 64 bit is not an
option for now.
The amount of RAM needed would probably depend on how many simultaneous
users you need to support. On a Linux box even 1 gig would work if you
are not loading it up with too many complex requests.
I can also imagine that certain custom written php scripts might
exercise the mapguide API in ways that can use arbitrary amounts of
memory, but that depends on you really. Also, I have seen some raster
layers spike the memory usage significantly, so that's also a factor.
Traian
-----Original Message-----
From: Marcus Spurkel [mailto:mspurkel at pacbell.net]
Sent: Wednesday, July 19, 2006 2:51 AM
Subject: [mapguide-users] The "ideal" MapGuide server?
I was wondering if there was any consensus out there as to what the
ideal MapGuide server should consist of.  I know you can have portions
on separate machines but if it all needed to live on one box, what would
the spec look like?
1. Is a 64-bit CPU (and a 64-bit Linux distro) desirable?  Can MapGuide
even take advantage of 64-bit architecture?
2. How much RAM?  1GB?  2? 4?  Is it the more the better?  How much swap
space?
3. Any specific mobos or other hardware to avoid?
Any input would be greatly appreciated.
-Marcus
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060719/400f849d/attachment.html
More information about the Mapguide-users
