[mapguide-users] Re: MGOS apps not loading
Andrew DeMerchant andrew.demerchant at gemtec.ca
Mon Jul 24 10:24:44 EDT 2006
I've got a similar problem, but with IIS. I've never been able to get
AJAX working....
Dave Wilson wrote:
> If you are using Apache then there is a redirect for the ajaxviewer in
> the httpd.conf file I believe. This needs to be changed from localhost
> to your machine name or ip address. Search on localhost/mapguide and
> you should find it.
> Regards,
> Dave
> *From:* Robert Leeman [mailto:rleeman at eitnl.com]
> *Sent:* Monday, July 24, 2006 8:16 AM
> *To:* users at mapguide.osgeo.org
> *Subject:* [mapguide-users] Re: MGOS apps not loading
> Hi Adam:
> This sounds like the same problem I have posted on a couple of times
> ... applications not loading.  While a browser refresh (or sometimes
> several of them) will generally fix that session it's not very good
> for our users.  We are using Windows Server 2003
> with Apache/PHP standard MGOS install.  I have not tested Autodesk MG
> Enterprise yet to see if this problem got fixed there.  Sorry for no
> solution here.  I just wanted to reiterate that we are having the same
> problem.
> Bob Leeman
> EIT (NL) Limited
> 20 Mercer's Drive
> St. John's, NL   A1A 2X1
> Canada
> Tel: 709-738-1638
> rleeman at eitnl.com <mailto:rleeman at eitnl.com>   www.eitnl.com
> <http://www.eitnl.com>
>     ----- Original Message -----
>     *From:* Adam Herbert <mailto:adam at aemsaustralia.com.au>
>     *To:* users at mapguide.osgeo.org <mailto:users at mapguide.osgeo.org>
>     *Sent:* Saturday, July 22, 2006 1:49 AM
>     *Subject:* [mapguide-users] MGOS apps not loading
>     Hi,
>     Wondering if anyone has ever got the AJAX map viewer to load on
>     Windows 2003 IIS 6? I can load map viewer fine when browsing on
>     the local machine but when I access the same from a remote machine
>     it has the question marks and a blank map.
>     Any suggestions would be greatly appreciated.
>     Thanks.
>     **Adam Herbert***
>     *IT Manager
>     AEM Solutions Pty Ltd
>     PO Box____ 514, Toowoomba Q. 4350
>     Phone: 07 4613 0455
>     Cell: 0437 599 907
>     Website: www.aemsaustralia.com.au
>     <blocked::BLOCKED::http://www.aemsaustralia.com.au>
	*Andrew DeMerchant*
*Computer Technologist*
ph.1-877-4GEMTEC x.163
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
Fredericton, NB, Canada
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide-users mailing list
