[mapguide-users] PhpApi problem
Marcus Spurkel
mspurkel at pacbell.net
Thu Jul 27 02:54:47 EDT 2006
That worked! It compiles fine and I'm all good now. Thanks for your help.
-Marcus
Trevor Wekel wrote:
>Hi Marcus,
>"make clean" and "make" in Web/src/PhpApi should be enough to rebuild
>the Web Extensions API for PHP. Check the timestamp on MgApi_wrap.cpp.
>It should be generated by "make".
>I suspect you should also be running into compilation problems if you've
>swapped out 5.0.5 with 5.1.4. We applied some #ifndef statements to
>php.h in PHP 5.0.5 to work around header dependencies between PHP and
>ACE. I would be surprised if these dependencies had been resolved.
>Here is a diff of the changes we made. If php.h is similar in 5.1.4,
>you may be able to apply these changes to it.
>*** \php-5.0.5\main\php.h Wed Jun 29 00:41:15 2005
>--- php.h Thu Feb 23 04:25:52 2006
>*** 38,78 ****
>--- 38,82 ----
> #include "zend_API.h"
> #undef sprintf
> #define sprintf php_sprintf
> /* PHP's DEBUG value must match Zend's ZEND_DEBUG value */
> #undef PHP_DEBUG
> #define PHP_DEBUG ZEND_DEBUG
> #ifdef PHP_WIN32
>+ #ifndef PHPPROXYAPI_EXPORTS
> #include "tsrm_win32.h"
> #include "win95nt.h"
>+ #endif
> # ifdef PHP_EXPORTS
> # define PHPAPI __declspec(dllexport)
> # else
> # define PHPAPI __declspec(dllimport)
> # endif
> #define PHP_DIR_SEPARATOR '\\'
> #define PHP_EOL "\r\n"
> #else
> #define PHPAPI
> #define THREAD_LS
> #define PHP_DIR_SEPARATOR '/'
> #if defined(__MacOSX__)
> #define PHP_EOL "\r"
> #else
> #define PHP_EOL "\n"
> #endif
> #endif
> #include "php_regex.h"
>+ #endif
> #if HAVE_ASSERT_H
> #if PHP_DEBUG
> #undef NDEBUG
> #else
> #ifndef NDEBUG
> #define NDEBUG
> #endif
> #endif
> #include <assert.h>
>*** 130,152 ****
>--- 134,158 ----
> #undef strlcat
> #define strlcat php_strlcat
> #endif
> #ifndef HAVE_STRTOK_R
> BEGIN_EXTERN_C()
> char *strtok_r(char *s, const char *delim, char **last);
> END_EXTERN_C()
> #endif
> #ifndef HAVE_SOCKLEN_T
> typedef unsigned int socklen_t;
> #endif
>+ #endif
> #define CREATE_MUTEX(a, b)
> #define SET_MUTEX(a)
> #define FREE_MUTEX(a)
> * Then the ODBC support can use both iodbc and Solid,
> * uncomment this.
> * #define HAVE_ODBC (HAVE_IODBC|HAVE_SOLID)
>*** 382,402 ****
>--- 388,410 ----
> #ifdef ZTS
> #define VIRTUAL_DIR
> #endif
> #include "php_streams.h"
> #include "php_memory_streams.h"
> #include "fopen_wrappers.h"
> /* Virtual current working directory support */
> #include "tsrm_virtual_cwd.h"
>+ #endif /* resolse TSRM conflicts */
> #include "zend_constants.h"
> /* connection status states */
> #define PHP_CONNECTION_NORMAL 0
> #define PHP_CONNECTION_ABORTED 1
> #define PHP_CONNECTION_TIMEOUT 2
> #include "php_reentrancy.h"
>-----Original Message-----
>From: Marcus Spurkel [mailto:mspurkel at pacbell.net]
>Sent: Tuesday, July 25, 2006 4:10 PM
>To: users at mapguide.osgeo.org
>Subject: Re: [mapguide-users] PhpApi problem
>Too many to count. Many of the "'zend_xxx' was not declared in this
>scope" variety. But I just realized something: all I did was swap out
>Oem/php with 5.1.4, then "make clean" and "make" in Web/src/PhpApi. I
>probably have to go back farther than that, don't I? Do I need to
>re-make the entire project?
>-Marcus
>Traian Stanev wrote:
>>I recently replaced Oem/php with 5.1.4 and it compiled fine for me. But
>>I did that on Windows.
>>What kinds of errors are you getting?
>>Traian
>>Sent: Tuesday, July 25, 2006 2:44 PM
>>Subject: [mapguide-users] PhpApi problem
>>I'm getting a "undefined symbol: empty_string in Unknown on line 0"
>>error when I try to load libphp_MapGuideApi.so into PHP. It's probably
>>because I'm trying to use PHP 5.1.4, which has some significant changes
>>to the Zend code (among other things). I tried replacing Oem/php with
>>the latest source version from php.net and then re-making PhpApi but
>>that generated a ton of errors. Is there an easy way to get it to run
>>with PHP 5.1.4, or will I need to back my version down to 5.0.5?
>>-Marcus
>>To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users
