Data Connection - SQL Databases
Lockyer James
James.Lockyer at bradford.nhs.uk
Fri Jul 28 09:12:21 EDT 2006
I'm trying to connect through to an SQL database. I've tried the FDO - SQL option but I can't seem to be able to configure the geography. I've tried the ODBC connection but studio crashes everytime I try and make the layer. Any clues?
I'd read somewhere that the current ODBC was only compatible with MS Access - is this still the case?
I'm running the Preview version of Studio (v1.0.0.17804) on the preview version of Enterprise. OS on the server is Win 2003 - IIS 6.
regards
Jim
This e-mail is intended for the use of the addressee only and may contain confidential information, copyright material or views/opinions that do not necessarily reflect those of the organisation. If you receive this email by mistake please advise the sender immediately. All should be aware that this email may be subject to public disclosure under the Freedom of Information Act 2000 and that emails may be monitored.
More information about the Mapguide-users
