[mapguide-users] Use ODBC data for tool tip
Dave Wilson
dave.wilson at autodesk.com
Thu Jun 1 10:31:58 EDT 2006
Hi Thomas,
on your datasource for your layer you need to execute a join.
The primary column is for the key column from your datasource that matches a key in your odbc datasource. The secondary column is the join key from your ODBC database.
When building your layer you need to select the extended feature class name from your join. If the layer is already built you will need to reselect the datasource to populate the drop down. Otherwise build a new layer.
When selecting the geometry use the original geometry from your datasource, do not use the new geometry from the join.
You should see the new columns from your odbc datasource appear in the layer properties. Change the Display name if you like.
You should then be able to use the new columns in the tooltip expression.
Regards,
Dave
-----Original Message-----
Sent: Thursday, June 01, 2006 7:00 AM
Subject: [mapguide-users] Use ODBC data for tool tip
we are trying to get the data out of a joined ODBC database for showing them as a tooltip ... Is there any documentation or any tip available ?
Mit freundlichen Grüßen
Thomas Grosser
- Geschäftsleitung -
Kom21 - Nürnberg
Großweidenmühlstraße 28
90419 Nürnberg
Tel.: 0911 - 378 33 85
Fax: 0911 - 378 33 86
Web: www.kom21.de
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users
