SDF file won't load in Studio. File too big?
Robert Leeman
rleeman at eitnl.com
Fri Jun 2 11:46:44 EDT 2006
Further to my email below, I don't think the issue is with Studio. I can't
publish a 266Mb SDF to MGOS from Autodesk Map either.
Bob Leeman
----- Original Message -----
To: "MapGuide Users List" <users at mapguide.osgeo.org>
Sent: Friday, June 02, 2006 12:41 PM
Subject: [mapguide-users] SDF file won't load in Studio. File too big?
> Do we know if there is a size restriction on SDF files that can be loaded
> in Studio? The largest file I have been able to load is 148Mb. I have a
> couple of other files over 200Mb that will not load. After trying for a
> while, Studio reports "Site... does not exist or internet connection has
> been lost...". The same problem was discussed on this list on March 22
> but I did not see a resolution that works for me. I am doing this with a
> localhost server using local data so it's not a remote server access
> issue. If there is a size restriction then that should be addressed and,
> in the short-term, is there a work-around? BTW, my SDF files are valid as
> they work fine in Autodesk Map 3D 2007 and are the proper MGOS SDF
> version.
> Also, I concur with previous discussion that suggests that MGOS should use
> data source pointers instead of having to make additional copies of source
> data in the library, both to facilitate data updates and to cut down on
> redundant use of drive space.
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users
