[mapguide-users] aclocal - warning on Fedora ...
Mandar Sarlashkar
mann.sar at gmail.com
Fri Jun 9 10:38:59 EDT 2006
Dear *Walt Welton-Lair !
Just recently I have moved to Linux...
To show that Java has been installed... I am copying some of the commands
that i have run...
*[root at localhost mapguide-1.0.0]# rpm -qa jdk
jdk-1.5.0_07-fcs
[root at localhost mapguide-1.0.0]# cd /usr/java/
[root at localhost java]# ls
jdk1.5.0_07
Is there anyway I can check if java has been installed properly or not..
What would have gone wrong... Shall I Start again from the beginning... I
mean Remove all packages and Install them again...
Thanks a lot for your kind help...
Mandy
On 6/9/06, Walt Welton-Lair <walt.welton-lair at autodesk.com> wrote:
> The aclocal warnings have nothing to do with your errors.
> The error below looks like a Java configuration problem. Did you install
> Java correctly? Use the latest version from java.sun.com.
> *From:* Mandar Sarlashkar [mailto:mann.sar at gmail.com]
> *Sent:* Friday, June 09, 2006 8:26 AM
> *To:* users at mapguide.osgeo.org
> *Subject:* Re: [mapguide-users] aclocal - warning on Fedora ...
> But When I run
> # make
> I am getting following Error...
> MgApi_wrap.cpp:56196: error: 'JNIEXPORT' does not name a type
> MgApi_wrap.cpp:56204: error: 'JNIEXPORT' does not name a type
> MgApi_wrap.cpp:56212: error: 'JNIEXPORT' does not name a type
> MgApi_wrap.cpp:56220: error: 'JNIEXPORT' does not name a type
> make[4]: *** [MgApi_wrap.lo] Error 1
> make[4]: Leaving directory `/usr/local/mapguide-1.0.0/Web/src/JavaApi'
> make[3]: *** [all] Error 2
> make[3]: Leaving directory `/usr/local/mapguide-1.0.0/Web/src/JavaApi'
> make[2]: *** [all-recursive] Error 1
> make[2]: Leaving directory `/usr/local/mapguide-1.0.0/Web/src'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/usr/local/mapguide-1.0.0/Web'
> make: *** [all-recursive] Error 1
> And I am not able to Set up Server....
> Thanks
> Mandy
> > They are warnings - you can ignore them.
> > *Sent:* Friday, June 09, 2006 5:48 AM
> > *Subject:* [mapguide-users] aclocal - warning on Fedora ...
> > I am settingup Mapguide OpenSource on Fedora...
> > I am getting following warning after I run # aclocal
> > [root at localhost mapguide-1.0.0]# aclocal
> > acinclude.m4:7: warning: underquoted definition of MAP_HELP_STRING
> > run info '(automake)Extending aclocal'
> > or see
> > http://sources.redhat.com/automake/automake.html#Extending-aclocal
> > acinclude.m4:12: warning: underquoted definition of MAP_SUBST
> > acinclude.m4:19: warning: underquoted definition of MAP_FAST_OUTPUT
> > acinclude.m4:25: warning: underquoted definition of MAP_GEN_CONFIG_VARS
> > acinclude.m4:67: warning: underquoted definition of
> > MAP_GENERATE_MAKEFILES
> > acinclude.m4:74: warning: underquoted definition of MAP_OUTPUT
> > acinclude.m4:83: warning: underquoted definition of
> > MAP_DEFINE_TYPE_RLIM_T
> > acinclude.m4:108: warning: underquoted definition of
> > MAP_SUBST_EXPANDED_ARG
> > acinclude.m4:115: warning: underquoted definition of
> > MAP_EXPORT_ARGUMENTS
> > Can anybody Please explain me ....What am I expected to do... ?
> > Thanks in advance...
> > Mandy
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060609/9963b76b/attachment.html
More information about the Mapguide-users
