[mapguide-users] MG Opensource config issues
Zac Spitzer
zac.spitzer at gmail.com
Fri Jun 16 01:26:22 EDT 2006
check that IIS is configured to use ASP.NET 2.0 not the 1.14 for the
mapguide folder
z
On 6/16/06, kenny at keniginc.com <kenny at keniginc.com> wrote:
> List,
> in my earlier post here today, I indicated that I was having "Access
> Denied" error when attempting to test the config settings.
> After fiddling with it for a short while, I discovered that perhaps I
> was having that problem because I installed it in windows xp, instead
> of windows 2003 server.
> So, I installed it on windows 2003 server.
> When I attempted to test with this:
> http://localhost/mapguide/mapviewerajax/ajaxviewer.aspx?WEBLAYOUT=Library://ATest.WebLayout
> Instead of getting the error message on the manual which is this:
> Resource was not found: Library://ATest.WebLayout
> I got the following:
> Compiler Error Message: CS0246: The type or namespace name 'OSGeo'
> could not be found (are you missing a using directive or an assembly
> reference?)
> Source Error:
> Line 21: <%@ Import Namespace="System.Text" %>
> Line 22: <%@ Import Namespace="System.Web" %>
> Line 23: <%@ Import Namespace="OSGeo.MapGuide" %>
> Line 24:
> Line 25: <!-- #Include File="common.aspx -->
> Source File: C:\Program
> Files\MapGuideOpenSource\WebServerExtensions\www\mapviewernet\mainframe.aspx
> Line: 23
> Where did I go wrong?
> Please help!!
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
Zac Spitzer
http://whereszac.org
0405 847 168
More information about the Mapguide-users
