[mapguide-users] MG Opensource config issues
kenny at keniginc.com kenny at keniginc.com
Sat Jun 24 10:34:41 EDT 2006
list,
hate to keep bothering you about this but i am pretty stuck in the
early stages of this data loading process.
I have followed the instructions on the gettingStarted.pdf manual to
load a couple of sample data via the studio.
But so far, when I click on any of the layers per the manual to style
the appearance of the layer, I keep getting an erron on the web.config
file.
The error pretty much has problem with the authentication mode of the
mapagent.
the authentication mode on web.config is: <authentication="None">
When I installed the MG OS, i let the installer install and config it
for me since I am using the .net framework to code it.
What am i doing wrong?
I done several searches on the forum about this but came up empty.
Please guys help me to get through this.
thanks very much in advance
Quoting Andy Morsell <amorsell at spatialgis.com>:
> The easiest way to get going on authoring your own data is to use the
> GettingStartedGuide.pdf found in the default location of C:\Program
> Files\Autodesk\MapGuideStudio2007\Help.  Once you run through setting up and
> loading a couple of the sample data sources, you should be able to apply
> that to your own data.
> Andy
> -----Original Message-----
> From: kenny at keniginc.com [mailto:kenny at keniginc.com]
> Sent: Friday, June 16, 2006 1:28 PM
> To: users at mapguide.osgeo.org
> Subject: RE: [mapguide-users] MG Opensource config issues
> list,
> I have successfully installed a demo of the MG OS app and everything seems
> to work real good.
> I want to extend a special "Thank you" to Andy Morsell for not only
> introduced  Mapguide Open Source to me but also referred me to this mailing
> list.
> Yet, he continued to respond to my posts.
> Thanks very much.
> The only question I have ( for now :) ) is how do I replace the
> Sheboygan.mgp file with my own shp / db files?
> any suggestions, samples will be truly appreciated.
>> Kenny,
>> I saw your other message in the old Autodesk MapGuide group appealing
>> for help on this.  I am just totally swamped in project work right now
>> or would spend more time on this specific issue.  I generally hate to
>> just brush off questions like this, but a lot of these initial
>> configuration and setup snags have been discussed over and over in
>> this list.  I'm sure we'll collectively (somehow) put together an
>> install and config FAQ or troubleshooting guide and have it on the
>> OSGEO Wiki, but for now, this list is all we have.  I find it much
>> easier to use this site for doing research on previously discussed topics:
>> http://www.nabble.com/OSGeo-MapGuide-f14845.html
>> Andy
>> Sent: Thursday, June 15, 2006 10:41 AM
>> Subject: [mapguide-users] MG Opensource config issues
>> List,
>> in my earlier post here today, I indicated that I was having "Access
> Denied"
>> error when attempting to test the config settings.
>> After fiddling with it for a short while, I discovered that perhaps I
>> was having that problem because I installed it in windows xp, instead
>> of windows
>> 2003 server.
>> So, I installed it on windows 2003 server.
>> When I attempted to test with this:
>> http://localhost/mapguide/mapviewerajax/ajaxviewer.aspx?WEBLAYOUT=Libr
>> ary://
>> ATest.WebLayout
>> Instead of getting the error message on the manual which is this:
>> Resource was not found: Library://ATest.WebLayout
>> I got the following:
>> Compiler Error Message: CS0246: The type or namespace name 'OSGeo'
>> could not be found (are you missing a using directive or an assembly
>> reference?)
>> Source Error:
>> Line 21: <%@ Import Namespace="System.Text" %> Line 22: <%@ Import
>> Namespace="System.Web" %> Line 23: <%@ Import
>> Namespace="OSGeo.MapGuide" %> Line 24:
>> Line 25: <!-- #Include File="common.aspx -->
>> Source File: C:\Program
>> Files\MapGuideOpenSource\WebServerExtensions\www\mapviewernet\mainfram
>> e.aspx
>>   Line: 23
>> Where did I go wrong?
>> Please help!!
>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
