[mapguide-users] MG Opensource config issues
Andy Morsell amorsell at spatialgis.com
Fri Jun 16 16:49:04 EDT 2006
The easiest way to get going on authoring your own data is to use the
GettingStartedGuide.pdf found in the default location of C:\Program
Files\Autodesk\MapGuideStudio2007\Help.  Once you run through setting up and
loading a couple of the sample data sources, you should be able to apply
that to your own data.
Andy
-----Original Message-----
From: kenny at keniginc.com [mailto:kenny at keniginc.com]
Sent: Friday, June 16, 2006 1:28 PM
Subject: RE: [mapguide-users] MG Opensource config issues
list,
I have successfully installed a demo of the MG OS app and everything seems
to work real good.
I want to extend a special "Thank you" to Andy Morsell for not only
introduced  Mapguide Open Source to me but also referred me to this mailing
list.
Yet, he continued to respond to my posts.
Thanks very much.
The only question I have ( for now :) ) is how do I replace the
Sheboygan.mgp file with my own shp / db files?
any suggestions, samples will be truly appreciated.
Quoting Andy Morsell <amorsell at spatialgis.com>:
> Kenny,
> I saw your other message in the old Autodesk MapGuide group appealing
> for help on this.  I am just totally swamped in project work right now
> or would spend more time on this specific issue.  I generally hate to
> just brush off questions like this, but a lot of these initial
> configuration and setup snags have been discussed over and over in
> this list.  I'm sure we'll collectively (somehow) put together an
> install and config FAQ or troubleshooting guide and have it on the
> OSGEO Wiki, but for now, this list is all we have.  I find it much
> easier to use this site for doing research on previously discussed topics:
> http://www.nabble.com/OSGeo-MapGuide-f14845.html
> Andy
> Sent: Thursday, June 15, 2006 10:41 AM
> Subject: [mapguide-users] MG Opensource config issues
> List,
> in my earlier post here today, I indicated that I was having "Access
Denied"
> error when attempting to test the config settings.
> After fiddling with it for a short while, I discovered that perhaps I
> was having that problem because I installed it in windows xp, instead
> of windows
> 2003 server.
> So, I installed it on windows 2003 server.
> When I attempted to test with this:
> http://localhost/mapguide/mapviewerajax/ajaxviewer.aspx?WEBLAYOUT=Libr
> ary://
> ATest.WebLayout
> Instead of getting the error message on the manual which is this:
> Resource was not found: Library://ATest.WebLayout
> I got the following:
> Compiler Error Message: CS0246: The type or namespace name 'OSGeo'
> could not be found (are you missing a using directive or an assembly
> reference?)
> Source Error:
> Line 21: <%@ Import Namespace="System.Text" %> Line 22: <%@ Import
> Namespace="System.Web" %> Line 23: <%@ Import
> Namespace="OSGeo.MapGuide" %> Line 24:
> Line 25: <!-- #Include File="common.aspx -->
> Source File: C:\Program
> Files\MapGuideOpenSource\WebServerExtensions\www\mapviewernet\mainfram
> e.aspx
>   Line: 23
> Where did I go wrong?
> Please help!!
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
