[mapguide-users] Pulling up Database resouces in Studio
Dave Wilson
dave.wilson at autodesk.com
Tue Jun 20 14:40:07 EDT 2006
Sorry for any confusion.
The Access database should be on the server for the best performance. If
you are uploading it from Studio and using a connection string rather
than a DSN it will reside on the server. Personally I would set up using
a DSN on the server and keep the database in a local data folder
somewhere. Trying to access an Access database across a network involves
getting permissions and user rights correct which can be annoying to
resolve.
Studio can be on any machine.
Dave
_____
From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
Sent: Tuesday, June 20, 2006 10:01 AM
Subject: RE: [mapguide-users] Pulling up Database resouces in Studio
Dave:
Thanks for the response. So you think it's best to run Studio directly
on the server? Yeah, I'm going through a proxy on my laptop. I don't
go through one on my PC, so I'll give this a try and see if it speeds
things up.
Thanks.
- Juan
_____
From: Dave Wilson [mailto:dave.wilson at autodesk.com]
Sent: Tuesday, June 20, 2006 11:59 AM
In general an Access database works VERY fast when it is stored locally,
remotely it's much slower. If you are on an external server do you have
a firewall and/or proxy server to contend with? This will also slow
things down.
Dave
_____
Sent: Tuesday, June 20, 2006 9:44 AM
Subject: [mapguide-users] Pulling up Database resouces in Studio
I've moved my MGOS stuff to our external server and when trying to pull
up my Access database resources in Studio, it takes a very, very, long
time. I'm just trying to make sure the connections are valid and
working. Is anyone else experiencing this? It's fine when I do
everything local. Is this a known issue when trying to connect to a
remote server?
FYI. Using IIS/.NET implementation.
- Juan
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060620/4f7740d3/attachment.html
More information about the Mapguide-users
