[mapguide-users] OGR Provider w/ PostGIS Support
Curtis W. Ruck
ruckc at yahoo.com
Mon Jun 26 13:42:03 EDT 2006
Wow, thanks, i added the view into the geometry columns table and it appears in mapguide....
Also date fields showup in mapguide studio...
the server stops crashing now that i can place a filter on the data...
Now i just can't get the layer of dots from my massive table ran though a view and filtered to appear on the map (ajax). (The DWF viewer doesn't even show the other raster layers).
I have the style set to 0 to Infinity with a black dot.... this query should have approximately 1000 dots showing...
Curtis Ruck
Curtis W. Ruck wrote:
> Alright,
> I know the OGR Provider w/ PostGIS is kinda new. Because I think the
> mapguide set of tools has the best interface and ease of use I want to see
> it survive.
> I am currently having a few issues with this:
> 1) When i setup the data
> layer in MapGuide Studio i can't choose a view from postgres. I can only
> choose a table. As a workaround i wanted to see if i could filter the
> data, which brings me to number 2
Curtis,
I have reviewed the OGR Postgres/PostGIS driver code, and it seems that
if a named view were listed in the geometry_columns table it would
get listed as a layer of the file. I haven't tried this myself to verify.
The following query is used to get a list of all tables/views to be
represented as layers through OGR.
SELECT c.relname FROM pg_class c, geometry_columns g
WHERE (c.relkind in ('r','v') AND c.relname !~ '^pg'
AND c.relname::TEXT = g.f_table_name::TEXT)
I think this selects all relations (tables) of type 'r' or 'v' (which
I assume is table and view) for which the name does not start with 'pg'
and for which the name is in the geometry_columns table.
> 2) I want to filter the data on a
> timestamp field. In the MapGuide Studio interface i can't select the
> timestamp field to do a filter with.
OGR 1.3.2 does support postgres timestamp fields internally as a date field.
Possibly date type fields are not handled properly by the OGR FDO provider?
> 3) Because i can't do the two top
> items, its crashing the mapguide server because the table i am trying to
> draw on the screen has some odd 300,000 records all with a geometry column.
> Other than that though it looks good, just wish it would work.
Crashing? Hmm, I would have expected it just to be slow.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
More information about the Mapguide-users
