[mapguide-users] Layer Groupings, Andy can you help?
Jason Birch
Jason.Birch at nanaimo.ca
Thu Jun 29 23:27:10 EDT 2006
Andy's screen shot is further down the screen. The section that you provided gives the ability to set up different different scale ranges. Just off to the right of your screen shot, there should be a button called "Theme". This will reveal the area that Andy's screen shot shows, where you can either manually build your categories or click on the (different) Theme button at the top of this expanded area to build a classification using a wizard.
Jason
Sent: Thu 2006-06-29 7:35 PM
Subject: RE: [mapguide-users] Layer Groupings, Andy can you help?
I forgot to mention that I am using a point layer (shp file),
although, I will be needing a parcel layer eventually which also
requires layergroupings.
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060629/6eb1eb18/attachment.bin
More information about the Mapguide-users
