Fwd: PLease Help He
sukalyan chakraborty chakraborty.sarkar at gmail.com
Fri Jun 30 07:48:16 EDT 2006
---------- Forwarded message ----------
From: sukalyan chakraborty <chakraborty.sarkar at gmail.com>
Date: Jun 30, 2006 3:03 PM
Subject: PLease Help He
 please help me...
When I'm Running pages from MGStudio then it is running fine but
If I running like
http://localhost/mapguide/dotnetviewersample/ajaxtiledviewersample.aspx
or
http://localhost/mapguide/dotnetviewersample/dwfviewersample.aspx
then getting the error
 I'm using Framework v2.0.50727 Server Error in '/mapguide' Application.
 *Compilation Error* *Description: *An error occurred during the compilation
of a resource required to service this request. Please review the following
specific error details and modify your source code appropriately.
*Compiler Error Message: *CS0246: The type or namespace name 'OSGeo' could
not be found (are you missing a using directive or an assembly reference?)
*Source Error:*
   Line 17: <%@ Import Namespace="System.Collections" %>
Line 18: <%@ Import Namespace="System.IO" %>Line 19: <%@ Import
Namespace="OSGeo.MapGuide" %>Line 20: <script language="c#"
runat="server">
Line 21:
*Source File:* c:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\dotnetviewersample\utilityfunctions.aspx
   *Line:* 19
Show Detailed Compiler Output:
  C:\WINDOWS\system32>
"C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\csc.exe" /t:library
/utf8output /R:"C:\WINDOWS\assembly\GAC_32\System.EnterpriseServices\2.0.0.0__b03f5f7f11d50a3a\System.EnterpriseServices.dll"
/R:"C:\WINDOWS\assembly\GAC_MSIL\System.Web.Services\2.0.0.0__b03f5f7f11d50a3a\System.Web.Services.dll"
/R:"C:\WINDOWS\assembly\GAC_MSIL\System.Configuration\2.0.0.0__b03f5f7f11d50a3a\System.Configuration.dll"
/R:"C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorlib.dll"
/R:"C:\WINDOWS\assembly\GAC_MSIL\System\2.0.0.0__b77a5c561934e089\System.dll"
/R:"C:\WINDOWS\assembly\GAC_MSIL\System.Xml\2.0.0.0__b77a5c561934e089\System.Xml.dll"
/R:"C:\WINDOWS\assembly\GAC_32\System.Data\2.0.0.0__b77a5c561934e089\System.Data.dll"
/R:"C:\WINDOWS\assembly\GAC_MSIL\System.Web.Mobile\2.0.0.0__b03f5f7f11d50a3a\System.Web.Mobile.dll"
/R:"C:\WINDOWS\assembly\GAC_MSIL\System.Drawing\2.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll"
/R:"C:\WINDOWS\assembly\GAC_32\System.Web\2.0.0.0__b03f5f7f11d50a3a\System.Web.dll"
/out:"C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Temporary ASP.NET
<http://asp.net/>
Files\mapguide\6330db03\7cea0d17\App_Web_ajaxtiledviewersample.aspx.305c7238.rr15dqlk.dll"
/debug- /optimize+
/win32res:"C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Temporary
ASP.NET <http://asp.net/>
Files\mapguide\6330db03\7cea0d17\3tjlg3zd.res" /w:4 /nowarn:1659;1699
<http://asp.net/>
Files\mapguide\6330db03\7cea0d17\App_Web_ajaxtiledviewersample.aspx.305c7238.rr15dqlk.0.cs"
<http://asp.net/>
Files\mapguide\6330db03\7cea0d17\App_Web_ajaxtiledviewersample.aspx.305c7238.rr15dqlk.1.cs"
Microsoft (R) Visual C# 2005 Compiler version 8.00.50727.42
for Microsoft (R) Windows (R) 2005 Framework version 2.0.50727
Copyright (C) Microsoft Corporation 2001-2005. All rights reserved.
c:\Program Files\MapGuideOpenSource\WebServerExtensions\www\dotnetviewersample\utilityfunctions.aspx(19,11):
error CS0246: The type or namespace name 'OSGeo' could not be found
c:\Program Files\MapGuideOpenSource\WebServerExtensions\www\dotnetviewersample\utilityfunctions.aspx(39,24):
error CS0246: The type or namespace name 'MgMap' could not be found
c:\Program Files\MapGuideOpenSource\WebServerExtensions\www\dotnetviewersample\utilityfunctions.aspx(39,1):
error CS0246: The type or namespace name 'MgLayer' could not be found
c:\Program Files\MapGuideOpenSource\WebServerExtensions\www\dotnetviewersample\utilityfunctions.aspx(55,26):
error CS0246: The type or namespace name 'MgByteReader' could not be
Show Complete Compilation Source:
  Line 1:    <%--
Line 2:    Copyright (C) 2004-2006  Autodesk, Inc.
Line 3:    This library is free software; you can redistribute it and/or
Line 4:    modify it under the terms of version 2.1 of the GNU Lesser
Line 5:    General Public License as published by the Free Software Foundation.
Line 6:
Line 7:    This library is distributed in the hope that it will be useful,
Line 8:    but WITHOUT ANY WARRANTY; without even the implied warranty of
Line 9:    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
Line 10:   Lesser General Public License for more details.
Line 11:
Line 12:   You should have received a copy of the GNU Lesser General Public
Line 13:   License along with this library; if not, write to the Free Software
Line 14:   Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA
02110-1301  USA
Line 15:   --%>
Line 16:
Line 19:   <%@ Import Namespace="OSGeo.MapGuide" %>
Line 20:   <script language="c#" runat="server">
Line 21:
Line 22:   NameValueCollection GetParameters()
Line 23:   {
Line 24:       return Request.HttpMethod == "GET" ?
Request.QueryString : Request.Form;
Line 25:   }
Line 26:
Line 27:   void InitializeWebTier()
Line 28:   {
Line 29:       // Initialize web tier with the site configuration
file.  The config
Line 30:       // file should be in the same folder as this script.
Line 31:       //
Line 32:       string realPath = Request.ServerVariables["APPL_PHYSICAL_PATH"];
Line 33:       String configPath =  realPath + "webconfig.ini";
Line 34:       MapGuideApi.MgInitializeWebTier(configPath);
Line 35:   }
Line 36:
Line 37:   // Searches the map for a layer with the specified name.
Line 38:
Line 39:   MgLayer GetLayerByName(MgMap map, String layerName)
Line 40:   {
Line 41:       MgLayer layer = null;
Line 42:       for (int i = 0; i < map.GetLayers().GetCount(); i++)
Line 43:       {
Line 44:           MgLayer nextLayer = map.GetLayers().GetItem(i);
Line 45:           if (nextLayer.GetName() == layerName)
Line 46:           {
Line 47:               layer = nextLayer;
Line 48:               break;
Line 49:           }
Line 50:       }
Line 51:       return layer;
Line 52:   }
Line 53:
Line 54:   // Read the content from an MgByteReader and send it back
as the response.
Line 55:   void OutputReaderContent(MgByteReader byteReader,
HttpResponse response)
Line 56:   {
Line 57:       MemoryStream memBuf = new MemoryStream();
Line 58:
Line 59:       byte[] byteBuffer = new byte[1024];
Line 60:       int numBytes = byteReader.Read(byteBuffer, 1024);
Line 61:       while(numBytes > 0)
Line 62:       {
Line 63:           memBuf.Write(byteBuffer, 0, numBytes);
Line 64:           numBytes = byteReader.Read(byteBuffer, 1024);
Line 65:       }
Line 66:
Line 67:       response.ContentType = byteReader.GetMimeType();
Line 68:       byte [] content = memBuf.ToArray();
Line 69:       response.OutputStream.Write(content , 0, content.Length);
Line 70:   }
Line 71:
Line 72:   </script>
Line 73:
*Version Information:* Microsoft .NET Framework Version:2.0.50727.42;
ASP.NET <http://asp.net/> Version:2.0.50727.42
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060630/e8de699a/attachment.html
More information about the Mapguide-users mailing list
