[mapguide-users] PLease Help He
sukalyan chakraborty
chakraborty.sarkar at gmail.com
Fri Jun 30 08:19:16 EDT 2006
But John till now getting the same error
Look My Point:
I'm Successfully running the pages through MGStudio using
http://127.0.0.1/mapguide/mapviewerajax/?WEBLAYOUT=Library%3a%2f%2fLayers%2flayout.WebLayout
but it is giving error when i'm trying some sample pages using
http://127.0.0.1/mapguide/ ..... /pagename.aspx
such as dotnetviewer sample.
also when i'm browsing the path
C:\Program Files\MapGuideOpenSource\WebServerExtensions\www\mapviewernet
from IIS Window then also giving the error but it different ..
it then tells that Invalid username Or password .
the authentication window is not comming..
Please Help how Can I Get The Soltion.... Please...
On 6/30/06, John Cachat <jcachat at agti.com> wrote:
> Check the version of .Net for the "mapguide" web site. I had this problem
> just yesterday after installing the latest build of MG Enterprise 2007 to a
> fresh 2003 server. It seems the install either does not install .Net 2.0or does not set the correct version when it creates the virtual
> directory. Changing it from 1.0 to 2.0 fixed the problem for me.
> Hope that helps,
> John
> ________________________________
> From: sukalyan chakraborty [mailto:chakraborty.sarkar at gmail.com]
> Sent: Fri 6/30/2006 5:33 AM
> To: users at mapguide.osgeo.org
> Subject: [mapguide-users] PLease Help He
> please help me...
> When I'm Running pages from MGStudio then it is running fine but
> If I running like
> http://localhost/mapguide/dotnetviewersample/ajaxtiledviewersample.aspx
> or
> http://localhost/mapguide/dotnetviewersample/dwfviewersample.aspx
> then getting the error
> I'm using Framework v2.0.50727
> Server Error in '/mapguide' Application.
> Compilation Error
> Description: An error occurred during the compilation of a resource
> required to service this request. Please review the following specific error
> details and modify your source code appropriately.
> Compiler Error Message: CS0246: The type or namespace name 'OSGeo' could
> not be found (are you missing a using directive or an assembly reference?)
> Source Error:
> Line 17: <%@ Import Namespace="System.Collections" %>
> Line 18: <%@ Import Namespace="System.IO" %>
> Line 19: <%@ Import Namespace="OSGeo.MapGuide" %>
> Line 20: <script language="c#" runat="server">
> Line 21:
> Source File: c:\Program
> Files\MapGuideOpenSource\WebServerExtensions\www\dotnetviewersample\utilityfunctions.aspx Line:
> 19
> Show Detailed Compiler Output:
> C:\WINDOWS\system32>
> "C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\csc.exe" /t:library
> /utf8output
> /R:"C:\WINDOWS\assembly\GAC_32\System.EnterpriseServices\2.0.0.0__b03f5f7f11d50a3a\System.EnterpriseServices.dll"
> /R:"C:\WINDOWS\assembly\GAC_MSIL\System.Web.Services\2.0.0.0__b03f5f7f11d50a3a\System.Web.Services.dll"
> /R:"C:\WINDOWS\assembly\GAC_MSIL\System.Configuration\2.0.0.0__b03f5f7f11d50a3a\System.Configuration.dll"
> /R:"C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorlib.dll"
> /R:"C:\WINDOWS\assembly\GAC_MSIL\System\2.0.0.0__b77a5c561934e089\System.dll"
> /R:"C:\WINDOWS\assembly\GAC_MSIL\System.Xml\2.0.0.0__b77a5c561934e089\System.Xml.dll"
> /R:"C:\WINDOWS\assembly\GAC_32\System.Data\2.0.0.0__b77a5c561934e089\System.Data.dll"
> /R:"C:\WINDOWS\assembly\GAC_MSIL\System.Web.Mobile\2.0.0.0__b03f5f7f11d50a3a\System.Web.Mobile.dll"
> /R:"C:\WINDOWS\assembly\GAC_MSIL\System.Drawing\2.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll"
> /R:"C:\WINDOWS\assembly\GAC_32\System.Web\2.0.0.0__b03f5f7f11d50a3a\System.Web.dll"
> /out:"C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Temporary
> ASP.NETFiles\mapguide\6330db03\7cea0d17\App_Web_ajaxtiledviewersample.aspx.305c7238.rr15dqlk.dll"
> /debug- /optimize+
> /win32res:"C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Temporary
> ASP.NET Files\mapguide\6330db03\7cea0d17\3tjlg3zd.res" /w:4
> /nowarn:1659;1699 "C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Temporary
> ASP.NETFiles\mapguide\6330db03\7cea0d17\App_Web_ajaxtiledviewersample.aspx.305c7238.rr15dqlk.0.cs"
> ASP.NETFiles\mapguide\6330db03\7cea0d17\App_Web_ajaxtiledviewersample.aspx.305c7238.rr15dqlk.1.cs"
> Microsoft (R) Visual C# 2005 Compiler version 8.00.50727.42
> for Microsoft (R) Windows (R) 2005 Framework version 2.0.50727
> Copyright (C) Microsoft Corporation 2001-2005. All rights reserved.
> c:\Program
> Files\MapGuideOpenSource\WebServerExtensions\www\dotnetviewersample\utilityfunctions.aspx(19,11):
> error CS0246: The type or namespace name 'OSGeo' could not be found (are you
> c:\Program
> Files\MapGuideOpenSource\WebServerExtensions\www\dotnetviewersample\utilityfunctions.aspx(39,24):
> error CS0246: The type or namespace name 'MgMap' could not be found (are you
> c:\Program
> Files\MapGuideOpenSource\WebServerExtensions\www\dotnetviewersample\utilityfunctions.aspx(39,1):
> error CS0246: The type or namespace name 'MgLayer' could not be found (are
> c:\Program
> Files\MapGuideOpenSource\WebServerExtensions\www\dotnetviewersample\utilityfunctions.aspx(55,26):
> error CS0246: The type or namespace name 'MgByteReader' could not be found
> Show Complete Compilation Source:
> Line 1: <%--
> Line 2: Copyright (C) 2004-2006 Autodesk, Inc.
> Line 3: This library is free software; you can redistribute it and/or
> Line 4: modify it under the terms of version 2.1 of the GNU Lesser
> Line 5: General Public License as published by the Free Software
> Foundation.
> Line 6:
> Line 7: This library is distributed in the hope that it will be useful,
> Line 8: but WITHOUT ANY WARRANTY; without even the implied warranty of
> Line 9: MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
> GNU
> Line 10: Lesser General Public License for more details.
> Line 11:
> Line 12: You should have received a copy of the GNU Lesser General
> Public
> Line 13: License along with this library; if not, write to the Free
> Software
> Line 14: Foundation, Inc., 51 Franklin St, Fifth Floor, Boston,
> MA 02110-1301 USA
> Line 15: --%>
> Line 16:
> Line 21:
> Line 22: NameValueCollection GetParameters()
> Line 23: {
> Line 24: return Request.HttpMethod == "GET" ? Request.QueryString :
> Request.Form;
> Line 25: }
> Line 26:
> Line 27: void InitializeWebTier()
> Line 28: {
> Line 29: // Initialize web tier with the site configuration
> file. The config
> Line 30: // file should be in the same folder as this script.
> Line 31: //
> Line 32: string realPath = Request.ServerVariables
> ["APPL_PHYSICAL_PATH"];
> Line 33: String configPath = realPath + "webconfig.ini";
> Line 34: MapGuideApi.MgInitializeWebTier(configPath);
> Line 35: }
> Line 36:
> Line 37: // Searches the map for a layer with the specified name.
> Line 38:
> Line 39: MgLayer GetLayerByName(MgMap map, String layerName)
> Line 40: {
> Line 41: MgLayer layer = null;
> Line 42: for (int i = 0; i < map.GetLayers().GetCount(); i++)
> Line 43: {
> Line 44: MgLayer nextLayer = map.GetLayers().GetItem(i);
> Line 45: if (nextLayer.GetName() == layerName)
> Line 46: {
> Line 47: layer = nextLayer;
> Line 48: break;
> Line 49: }
> Line 50: }
> Line 51: return layer;
> Line 52: }
> Line 53:
> Line 54: // Read the content from an MgByteReader and send it back as
> the response.
> Line 55: void OutputReaderContent(MgByteReader byteReader, HttpResponse
> response)
> Line 56: {
> Line 57: MemoryStream memBuf = new MemoryStream();
> Line 58:
> Line 59: byte[] byteBuffer = new byte[1024];
> Line 60: int numBytes = byteReader.Read(byteBuffer, 1024);
> Line 61: while(numBytes > 0)
> Line 62: {
> Line 63: memBuf.Write(byteBuffer, 0, numBytes);
> Line 64: numBytes = byteReader.Read(byteBuffer, 1024);
> Line 65: }
> Line 66:
> Line 67: response.ContentType = byteReader.GetMimeType();
> Line 68: byte [] content = memBuf.ToArray();
> Line 69: response.OutputStream.Write(content , 0, content.Length);
> Line 70: }
> Line 71:
> Line 72: </script>
> Line 73:
> Version Information: Microsoft .NET Framework Version:2.0.50727.42;
> ASP.NET Version:2.0.50727.42
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060630/3f15d3d6/attachment.html
More information about the Mapguide-users
