[mapguide-users] RE: Come get your Key IDs
Andrew DeMerchant andrew.demerchant at gemtec.ca
Fri Jun 30 10:03:40 EDT 2006
Ok, I've given up on the VBScipt plan. I don't think that it's possible
at all. My current plan is to make a little PHP page that will open, get
the data needed, and then post it to an ASP page that I will then be
able to do what I want with. Maybe when I'm done, I'll post the code so
that someone else can modify it to their needs. I would imagine that a
php file that returns actual data from selected features would prove
useful for a lot of people. I'll keep you posted. Thanks for the help.
Andrew
Andy Morsell wrote:
> Andrew,
> That documentation is for the older MapGuide 6.5 technology which is
> completely different than the new MapGuide which was re-written from
> the ground up and shares nothing in common with the older version.
> I'm afraid that documentation probably won't help you much with the
> new version.  All of the documentation for MapGuide Open Source is
> here: https://mapguide.osgeo.org/documentation.html.  All of the
> samples in the developer guide are PHP, however.  And, the .NET sample
> application is all C#.  Translating VB.NET to C#.NET and vice versa is
> not too difficult, though.
> Andy
> *From:* Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
> *Sent:* Thursday, June 29, 2006 12:55 PM
> *To:* users at mapguide.osgeo.org
> *Subject:* Re: [mapguide-users] RE: Come get your Key IDs
> Ok, I've actually found some documentation that may help me. (Found
> here: http://www.mapguide.com/Help/ver6.5/pdf/en/MGDevGuide6.pdf)
> This actually has some ASP (VBScript) documentation for a change. Of
> course, it's not for MapServer, but surely it must be similar, at
> least. At the very least, it's a start for me.
> Andrew
> Andrew DeMerchant wrote:
>> If it can be done with VB.Net, I'd imagine that it could be done with
>> VBScript....finding documentation on that might be tricky though. Is
>> there any documentation on using MapServer with VB.Net? That would
>> certainly be a start for me....I don't think that .Net is too
>> difficult to pick up from regular VB.
>> Kori Maleski wrote:
>>>Hi Andrew,
>>>It is indeed VB.NET - although I can switch it to C# easy enough.
>>>I don't think you can utilize VBScript server side for these operations (if anybody can correct me on this feel free).
>>>You will have to pick up a book on .NET basics - VB since you are more comfortable with it.
>>>You can get away with not purchasing Visual Studio by just coding in a text editor (you will lose the debugging ability).
>>>Note: My code is only a snippet and won't run without a larger part of code above it.
>>>Cheers,
>>>Kori Maleski  BSc.
>>>Senior Technical Consultant
>>>Pacific Alliance Technologies
>>>Suite 400 - 534 17 Ave. SW Calgary, AB CANADA T2S 0B1
>>>TEL 403.770.1917 FAX 877.691.9149 TOL 877.691.9171 www.pat.ca <http://www.pat.ca/>
>>>________________________________
>>>From: Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
>>>Sent: Thu 29/06/2006 12:37 PM
>>>To: users at mapguide.osgeo.org
>>>Subject: Re: [mapguide-users] RE: Come get your Key IDs
>>>Kori,
>>>Is your code VB.Net? The server-side code that I use will need to be VBScript (not VB.Net)....I tried your code, but it doesn't run, which is why I suspect that it's .Net....I'm a 'programming type', but not when it comes to PHP, C# or .Net. I can read them to some extent, but don't know that languages very well. Since I don't know PHP or C#, I've found the documentation pretty hard to follow. I'd LOVE it if you could just specify a field to pass for each layer without any coding involved. That would be a great addition. In the meantime, any help that I can get would be greatly appreciated. What I really need is to see some example VBScript code (I learn best by example) that shows how to get data from the "$CurrentSelection$" variable that gets passed with InvokeURL.
>>>Andrew
>>>Kori Maleski wrote:
>>>	Andy,
>>>	This code is part of a generic handler so I don't hardcode the column name and is reused in all the reporting functions.  I could have passed the name instead of the ordinal position.  I forget why I did that.  It must have been a Monday.
>>>	Kori Maleski  BSc.
>>>	TEL 403.770.1917 FAX 877.691.9149 TOL 877.691.9171 www.pat.ca <http://www.pat.ca/> <http://www.pat.ca/>
>>>	From: Andy Morsell [mailto:amorsell at spatialgis.com]
>>>	Sent: Thu 29/06/2006 11:33 AM
>>>	Subject: [BULK] RE: [mapguide-users] RE: Come get your Key IDs
>>>	Kori,
>>>	I don't think you have to know the column order.  In my case I am getting to it directly by field name.  I am creating the filter, query options and feature reader the same way, though.  Also, my MgPropertyType is hardcoded here.  Your way of determining it from the field is better.
>>>	Here is part of the C# code for it:
>>>	//loop through the featureReader, get the ID field, and add it to an array
>>>	ArrayList objDBID = new ArrayList(0);
>>>	while (featureReader.ReadNext())
>>>	        objDBID.Add(featureReader.GetString("ID")); //TO DO: un-hard code this.  Pick up the field name to be queried from a request parameter instead.
>>>	My biggest problem with these solutions is that the non-programmer types are not going to be able to easily do this.  We really need a way to easily pass ANY field in a given layer from a selection set client-side.
>>>	Andy
>>>	From: Kori Maleski [mailto:km at pat.ca]
>>>	Sent: Thursday, June 29, 2006 10:15 AM
>>>	Subject: [mapguide-users] RE: Come get your Key IDs
>>>	Andrew,
>>>	The Selection Set contains the featureIDs for your datasource.
>>>	You can get YOUR key IDs from the Selection set by querying the feature, then reading your preferred key Column (property).
>>>	You have to know your key columns position in order to do this - hence my variable - l_iKeyColumnOrdinal.
>>>	i.e. - if my key IDs are in column 4 then  l_iKeyColumnOrdinal = 4
>>>	I utilize a lookup table that manages my key columns.  Not sure if this is the best way but it works.
>>>	This returns MY key IDs in a column delimited string.
>>>	'query the features
>>>	Dim l_oQuery As New MgFeatureQueryOptions()
>>>	l_oQuery.SetFilter(l_sFilter) 'derived from selection set
>>>	Dim l_ofeatureSource As MgResourceIdentifier = New MgResourceIdentifier(l_oSelLayer.GetFeatureSourceId())
>>>	Dim l_ofeatures As MgFeatureReader = l_oFeatureSrvc.SelectFeatures(l_ofeatureSource, l_sFeatureClassName, l_oQuery)
>>>	If l_ofeatures.ReadNext() Then
>>>	Dim l_sProperty As String = l_ofeatures.GetPropertyName(l_iKeyColumnOrdinal)
>>>	Do
>>>	Dim pi As Integer
>>>	'For pi = 0 To l_ofeatures.GetPropertyCount() - 1
>>>	Dim l_iPropType As Integer = l_ofeatures.GetPropertyType(l_sProperty)
>>>	Dim l_sPropertyValue As String = ""
>>>	Select Case l_iPropType
>>>	Case MgPropertyType.Boolean
>>>	l_sPropertyValue = l_ofeatures.GetBoolean(l_sProperty).ToString()
>>>	Case MgPropertyType.Single
>>>	l_sPropertyValue = l_ofeatures.GetSingle(l_sProperty).ToString()
>>>	Case MgPropertyType.Double
>>>	l_sPropertyValue = l_ofeatures.GetDouble(l_sProperty).ToString()
>>>	Case MgPropertyType.Int16
>>>	l_sPropertyValue = l_ofeatures.GetInt16(l_sProperty).ToString()
>>>	Case MgPropertyType.Int32
>>>	l_sPropertyValue = l_ofeatures.GetInt32(l_sProperty).ToString()
>>>	Case MgPropertyType.Int64
>>>	l_sPropertyValue = l_ofeatures.GetInt64(l_sProperty).ToString()
>>>	Case MgPropertyType.String
>>>	l_sPropertyValue = l_ofeatures.GetString(l_sProperty)
>>>	End Select
>>>	If l_sSelectedLayerIDs = "" Then
>>>	l_sSelectedLayerIDs = l_sPropertyValue
>>>	Else
>>>	l_sSelectedLayerIDs = l_sSelectedLayerIDs + "," + l_sPropertyValue
>>>	End If
>>>	'Next pi
>>>	Loop While l_ofeatures.ReadNext()
>>>	Obviously you have to do this server side...
>>>	Cheers,
>>>	Kori Maleski  BSc.
>>>	Sent: Thu 29/06/2006 10:32 AM
>>>	Subject: Re: [mapguide-users] Andy - Question about your tooltips...
>>>	To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>>	For additional commands, e-mail: users-help at mapguide.osgeo.org
>> 	*Andrew DeMerchant*
>> *Computer Technologist*
>> ph.1-877-4GEMTEC x.163
>> fax 506-453-9470
>> /GEMTEC Limited <http://www.gemtec.ca>
>> /191 Doak Road
>> Fredericton, NB, Canada
>> E3C 2E6
> 	*Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
	*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide-users mailing list
