[mapguide-users] New web site - Forums or Mailing Lists?
Robert Bray
robert.bray at autodesk.com
Tue Mar 7 13:51:20 EST 2006
We plan to use the mailing lists for most communication. The archives
are fully searchable, but you are right the threaded view is pretty bad.
At times we will use forums for more targeted discussions, e.g.
gathering / discussing requirements for a new feature.
Bob
_____
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Tuesday, March 07, 2006 9:50 AM
Subject: RE: [mapguide-users] New web site - Forums or Mailing Lists?
I'd be OK with the mailing lists as long as the archive is conducive to
doing research, especially for new users. Then, maybe the forums are
only for "sticky" items and FAQ's that are placed there by admins only,
much as it appears now. I'm looking at the mailing list archive (from
this morning's messages) on the By Thread tab and seeing that the
messages are not threaded correctly.
Andy
_____
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Tuesday, March 07, 2006 8:38 AM
I really prefer mailing lists. I hate going to multiple sources, for
the same reason that I use a blog aggregator instead of visiting each
site. With so much going on right now, I like to be able to set up a
filter and then quickly run through the messages when I get a second.
I understand where Andy's coming from with the research perspective, but
from an active participation point of view email is far easier and less
intrusive.
Is it possible to gateway the mailing list to a forum? And/or create an
RSS feed for the forums?
Jason
_____
Sent: Tuesday, March 07, 2006 08:28
Subject: [mapguide-users] New web site - Forums or Mailing Lists?
With the new web site, there is now a discussion forums section. Right
now there are two sections, but I assume more will be added. Will the
forums be the preferred way for general developer and user discussions
or will this email list continue to be the primary method? I would
prefer the forums be the main repository for discussion as I find them
much easier to do research on historic topics due to their threaded
nature. I know there are all kinds of opinions on this, but it seems
like there should be one or the other.
Also, are the older mse-users mailing list archives going to be migrated
into the current archives?
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060307/d87b5d41/attachment.html
More information about the Mapguide-users
