[mapguide-users] New configuration problems
Eric Brown
ericbrown at netxn.com
Sun Mar 12 16:19:14 EST 2006
Bill,
Thank you - that's pretty much what I did, and I'm now able to connect.
Now, it's just a matter of getting things to work! Ha...
I've played a bit with the Getting Started guide, things seem a bit "buggy" :) - I'm a bit scared to even think of loading my parcel shape file just based on issues with the small files supplied - I think mine might send it to the grave.
However, if it can do what I hope it can - it'll be a great tool.
Any insight is always greatly appreciated.
Thanks,
-- Eric
----- Original Message -----
Sent: Sunday, March 12, 2006 1:07 PM
Subject: RE: [mapguide-users] New configuration problems
Hi Eric,
Here are some more detailed instructions. These might help you identify where it's going wrong. During steps 2-7 you should not see the word "Mapserver appear as part of a download or install.
1.. Use the Windows "Add or Remove Programs" dialog to remove the currently installed MapGuide Studio (or MapServer Studio).
2.. Go to this URL: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=6153839
3.. Scroll to the bottom of the page. You should see a picture of a Garmin device, and a paragraph with the heading "The MapGuide Open"
4.. Just above that, there is link that reads: StudioSetup.exe (exe - 125407 Kb). Right click on it and download/save it to your file system.
5.. In the Windows File Explorer, right-click on the StudioSetup.exe file that you downloaded in step 4 and select Properties. The "Size:" should read: 126 MB (132,695,040 bytes)
6.. Now run the StudioSetup.exe that you downloaded in step 4.
7.. Confirm that the install was successful by opening the Windows "Add or Remove Programs" dialog. There should be an entry for "Autodesk MapGuide ® Studio Preview. Click on it, and the "Click here for support information" link will appear. Click on that link and you will see a text box indicating the version number. It should read 1.0.0.16407.
Let me know how it goes,
Bill
Sent: Sunday, March 12, 2006 12:24 PM
Subject: Re: [mapguide-users] New configuration problems
Bill,
Thanks - that's very strange. Somehow I downloaded Mapserver studio instead of Mapguide studio. Perhaps I'm confused - I'm under the impression that Mapguide Open Source server is really Mapserver. At any rate, I was somehow able to download Mapserver Studio (which has the exact same size footprint and file name as Mapguide Studio).
Please advise,
-- Eric
To: users at mapguide.osgeo.org ; ericbrown at netxn.xom
Sent: Sunday, March 12, 2006 5:40 AM
Hi Eric,
The "version is incompatible" message probably means that you have an old Studio. A new one got posted last week to www.autodesk.com/mapguidestudio with a version number of 1.0.0.16407 (you can use the Help About dialog to confirm the version). If you download and install the new one, that should fix your problem
Bill
Sent: Sunday, March 12, 2006 8:35 AM
To: users at mapguide.osgeo.org; ericbrown at netxn.xom
Hi Eric,
The mgp file itself is just a zip file containing all the map resources. Sometimes Internet Explorer changes the extensions of files it recognizes, so it likely renamed it to .zip when it downloaded it. Just rename it to .mgp.
As far as the Studio problem, let's wait for someone else (who knows better) to answer that. But I am puzzled that you say MapServer Studio... That's what the 0.9 version was called, the current one should say MapGuide Studio when it starts up.
Traian
-----Original Message-----
Sent: Sun 3/12/2006 3:14 AM
Cc:
Subject: [mapguide-users] New configuration problems
All...
Just downloaded MapGuide & Mapserver Studio.
While the Admin appears to function fairly properly - I can't connect from studio, receiving the following message: "The Studio version is incompatible with the site version."
Since I downloaded both files today my assumption would be that all would be synched properly.
Additionally, though I believe these may be related based on other posts.. the sheboygan.mgp download file isn't a .mgp but rather a .zip file doesn't include a the sheboygan.mgp file. And I've tried just putting the .zip file in the C:\Program Files\MapGuideOpenSource\Server\Packages folder to no avail, the admin doesn't see a package.
So.. I'm at somewhat of an impasse because I can't get the demo apps to run because of no data, and I can't play with the development tool due to a version conflict.
Any assistance would be greatly appreciated.
-- Eric
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060312/60ec0f1e/attachment.html
More information about the Mapguide-users
