[mapguide-users] Fix for NULL geomtry in shp->sdf load
James Card james.card at calcad.com
Fri Mar 17 13:52:55 EST 2006
On Fri, 17 Mar 2006 07:53:30 -0800, Edward Zimmerman
<edward.zimmerman at autodesk.com> wrote:
> It turns out that our shp->sdf conversion code was failing to insert a
> feature from the source shp file into the destination sdf file whenever
> the geometry property of the source feature is NULL.
> The relevant Studio code has been fixed, and a patched dll has been
> posted at
> <https://mapguide.osgeo.org/files/documents/12/40/Autodesk.MapGuide.Studio.Fdo.zip>
> . To apply this patched dll to your current Studio Preview installation,
> unzip this dll, overwriting the existing one (ex: C:\Program
> Files\Autodesk\MapGuideStudioPreview\Autodesk.MapGuide.Studio.Fdo.dll)
Hurray!  Thank you! I was having exactly the same problem and that fixed
it.
James Card
California CAD Solutions, Inc.
209 578-5580 Voice
209 521-6493 FAX
More information about the Mapguide-users mailing list
