Fix for NULL geomtry in shp->sdf load
Edward Zimmerman edward.zimmerman at autodesk.com
Fri Mar 17 10:53:30 EST 2006
I did a further investigation of the problem Andy describes below when
attempting to load a particular Shape file. It turns out that our
shp->sdf conversion code was failing to insert a feature from the source
shp file into the destination sdf file whenever the geometry property of
the source feature is NULL.
The relevant Studio code has been fixed, and a patched dll has been
posted at
https://mapguide.osgeo.org/files/documents/12/40/Autodesk.MapGuide.Studi
o.Fdo.zip
<https://mapguide.osgeo.org/files/documents/12/40/Autodesk.MapGuide.Stud
io.Fdo.zip> . To apply this patched dll to your current Studio Preview
installation, unzip this dll, overwriting the existing one (ex:
C:\Program
Files\Autodesk\MapGuideStudioPreview\Autodesk.MapGuide.Studio.Fdo.dll)
Ed
  _____
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Friday, March 10, 2006 2:25 PM
Subject: [mapguide-users] Problems Loading Data
I am having a problem loading a particular Shape file onto the server.
It loads fine if I do not have Convert to SDF Feature Source checked.
However, due to the very poor performance I am seeing with Shape files,
I am finding it necessary to convert everything to SDF at load time.
When I try to execute this load procedure in Studio, I get an error
message of: "Operation is not valid due to the current state of the
object".  I have tried closing Studio, restarting the MapGuide service,
saving it as a package, etc., but nothing helps.  The error pops up
almost immediately after pressing the Load Resources button.   This is a
point shape file of county ownership information.  The DBF file is about
70 MB.  I can supply this Shape file to Autodesk if needed.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com <http://www.SpatialGIS.com>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060317/6800afa8/attachment.html
More information about the Mapguide-users mailing list
