[mapguide-users] MGOS build problem on windows 2003
velen
vliang at thecarbonproject.com
Tue Mar 21 17:57:20 EST 2006
We're experiencing difficulty building mapguide open source on a Windows
2003 server (standard edition). There were a few link errors when building
"Server" solution; most of them are LNK1104: can not open file. There were
no error in the previous steps when building FDO and OEM.
Any suggestion will be appreciated. Thank you for your help in advance!
Velen Liang | www.TheCarbonProject.com
Error messages as follow:
1>------ Build started: Project: ServerManager, Configuration: Debug Win32
2>------ Build started: Project: GwsCommon, Configuration: Debug Win32
1>Linking...
1>LINK : fatal error LNK1104: cannot open file 'Fdo.lib'
1>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Server\obj\debug\ServerManager\BuildLog.h
tm"
1>ServerManager - 1 error(s), 0 warning(s)
3>------ Build started: Project: ServerBase, Configuration: Debug Win32
3>Linking...
2>Linking...
3>LINK : fatal error LNK1104: cannot open file
'..\..\..\lib\debug\mgservermanagerd.lib'
2>LINK : fatal error LNK1104: cannot open file 'Fdo.lib'
2>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Server\obj\debug\GwsCommon\BuildLog.htm"
2>GwsCommon - 1 error(s), 0 warning(s)
3>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Server\obj\debug\ServerBase\BuildLog.htm"
3>ServerBase - 1 error(s), 0 warning(s)
4>------ Build started: Project: GwsQueryEngine, Configuration: Debug Win32
5>------ Build started: Project: ServerResourceService, Configuration: Debug
Win32 ------
4>Linking...
4>LINK : fatal error LNK1104: cannot open file 'Fdo.lib'
4>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Server\obj\debug\GwsQueryEngine\BuildLog.
htm"
4>GwsQueryEngine - 1 error(s), 0 warning(s)
5>Linking...
5>LINK : fatal error LNK1104: cannot open file
6>------ Build started: Project: Stylization, Configuration: Debug Win32
5>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Server\obj\debug\Services\Resource\BuildL
og.htm"
5>ServerResourceService - 1 error(s), 0 warning(s)
7>------ Build started: Project: ServerFeatureService, Configuration: Debug
Win32 ------
7>Linking...
7>LINK : fatal error LNK1104: cannot open file 'Fdo.lib'
7>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Server\obj\debug\Services\Feature\BuildLo
g.htm"
7>ServerFeatureService - 1 error(s), 0 warning(s)
8>------ Build started: Project: ServerAdminService, Configuration: Debug
Win32 ------
8>Linking...
8>LINK : fatal error LNK1104: cannot open file
6>Linking...
8>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Server\obj\debug\Services\ServerAdmin\Bui
ldLog.htm"
8>ServerAdminService - 1 error(s), 0 warning(s)
6>LINK : fatal error LNK1104: cannot open file 'GisCommon.lib'
6>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Common\obj\debug\Stylization\BuildLog.htm
6>Stylization - 1 error(s), 0 warning(s)
9>------ Build started: Project: ServerSiteService, Configuration: Debug
Win32 ------
9>Linking...
9>LINK : fatal error LNK1104: cannot open file
'..\..\..\lib\debug\mgserverresourceserviced.lib'
9>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Server\obj\debug\Services\Site\BuildLog.h
tm"
9>ServerSiteService - 1 error(s), 0 warning(s)
10>------ Build started: Project: ServerMappingService, Configuration: Debug
Win32 ------
11>------ Build started: Project: ServerDrawingService, Configuration: Debug
Win32 ------
10>Linking...
10>LINK : fatal error LNK1104: cannot open file 'Fdo.lib'
10>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Server\obj\debug\Services\Mapping\BuildLo
g.htm"
10>ServerMappingService - 1 error(s), 0 warning(s)
11>Linking...
11>LINK : fatal error LNK1104: cannot open file
11>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Server\obj\debug\Services\Drawing\BuildLo
g.htm"
11>ServerDrawingService - 1 error(s), 0 warning(s)
12>------ Build started: Project: ServerRenderingService, Configuration:
Debug Win32 ------
12>Linking...
12>LINK : fatal error LNK1104: cannot open file
'..\..\..\lib\debug\mgservermappingserviced.lib'
12>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Server\obj\debug\Services\Rendering\Build
Log.htm"
12>ServerRenderingService - 1 error(s), 0 warning(s)
13>------ Build started: Project: ServerTileService, Configuration: Debug
Win32 ------
13>Linking...
13>LINK : fatal error LNK1104: cannot open file
13>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Server\obj\debug\Services\Tile\BuildLog.h
tm"
13>ServerTileService - 1 error(s), 0 warning(s)
14>------ Build started: Project: ServerFactory, Configuration: Debug Win32
14>Linking...
14>LINK : fatal error LNK1104: cannot open file
'..\..\..\lib\debug\mgserversiteserviced.lib'
14>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Server\obj\debug\ServerFactory\BuildLog.h
tm"
14>ServerFactory - 1 error(s), 0 warning(s)
15>------ Build started: Project: ServerCore, Configuration: Debug Win32
15>Linking...
15>LINK : fatal error LNK1181: cannot open input file
'..\..\lib\debug\mgserversiteserviced.lib'
15>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Server\obj\debug\ServerCore\BuildLog.htm"
15>ServerCore - 1 error(s), 0 warning(s)
16>------ Build started: Project: UnitTesting, Configuration: Debug Win32
16>Linking...
16>LINK : fatal error LNK1104: cannot open file 'GisCommon.lib'
16>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Server\obj\debug\UnitTesting\BuildLog.htm
16>UnitTesting - 1 error(s), 0 warning(s)
17>------ Build started: Project: PostBuild, Configuration: Debug Win32
17>Performing Makefile project actions
17>Microsoft (R) Program Maintenance Utility Version 8.00.50727.42
17>Copyright (C) Microsoft Corporation. All rights reserved.
17>NMAKE : fatal error U1073: don't know how to make
'..\..\..\Common\bin\debug\MgStylizationd.dll'
17>Stop.
17>Project : error PRJ0019: A tool returned an error code from "Performing
Makefile project actions"
17>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Server\obj\debug\PostBuild\BuildLog.htm"
17>PostBuild - 2 error(s), 0 warning(s)
========== Build: 0 succeeded, 17 failed, 6 up-to-date, 0 skipped ==========
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060321/c8217844/attachment.html
More information about the Mapguide-users
