[mapguide-users] login
volunteer at spatiallink.org
Mon Mar 27 09:17:26 EST 2006
Rob,
ApacheMonitor.exe shows up as running under Task Manager [WIN2003].
I restart ApacheMapGuide and try to login to login.php, but get the
following error message:
"Authentication Failed. Please enter a valid username and password."
Harsh
> -------- Original Message --------
> Subject: RE: [mapguide-users] login
> From: "Robert Bray" <robert.bray at autodesk.com>
> Date: Sun, March 26, 2006 2:58 am
> To: <users at mapguide.osgeo.org>
> Cc: "Dave Wilson" <dave.wilson at autodesk.com>
> Harsh, Is the MapGuide Server Service installed and running? Sometimes it does not auto-start after install. Bob
> From: volunteer at spatiallink.org [mailto:volunteer at spatiallink.org]
> Sent: Saturday, March 25, 2006 5:38 PM
> To: users at mapguide.osgeo.org
> Cc: Dave Wilson
> Dave/Others-
> I am trying to install MapGuide OpenSource Web Server Extensions.
> I tried it on Windows XP Professional on both ports- #8008 with MS4W and #80 withOUT MS4W. I followed the instructions in https://mapguide.osgeo.org/docs/InstallConfigureMapGuideOnWindows.pdf for PHP. Then I tried logging-in to ../mapguide/mapadmin/login.php using 'Administrator' and 'admin' [case-sensitive] with both, Firefox and Internet Explorer. This leads to an 'incorrect login' error. Apache MapGuide service is running during these attempts.
> I am now trying the same on Windows 2003 Professional Server.
> Thanks, Harsh -------- Original Message --------
> From: "Dave Wilson" <dave.wilson at autodesk.com>
> Date: Fri, March 24, 2006 7:02 pm
> Could you kindly provide more details please?
> For example are you logging into the Webadmin php page? For example
> http://localhost:8008/mapguide/mapadmin/login.php for Apache.
> Are you getting an error message if so what is it?.
> Regards,
> Dave
> -----Original Message-----
> Sent: Friday, March 24, 2006 4:47 PM
> Subject: [mapguide-users] login
> username: Administrator
> password: admin
> ...do not work even when Apache MapGuide is running [WIN2003].
More information about the Mapguide-users
