[mapguide-users] login
Traian Stanev traian.stanev at autodesk.com
Mon Mar 27 09:21:11 EST 2006
Hi Harsh,
The MapGuide server is a service running in addition to your web server.
In the task manager, look for mgserver.exe. If that is not running you
will need to start it manually.
Traian
-----Original Message-----
From: volunteer at spatiallink.org [mailto:volunteer at spatiallink.org]
Sent: Monday, March 27, 2006 9:17 AM
Cc: Robert Bray; Dave Wilson
Subject: RE: [mapguide-users] login
Rob,
ApacheMonitor.exe shows up as running under Task Manager [WIN2003].
I restart ApacheMapGuide and try to login to login.php, but get the
following error message:
"Authentication Failed. Please enter a valid username and password."
Harsh
> -------- Original Message --------
> From: "Robert Bray" <robert.bray at autodesk.com>
> Date: Sun, March 26, 2006 2:58 am
> To: <users at mapguide.osgeo.org>
> Cc: "Dave Wilson" <dave.wilson at autodesk.com>
>  Harsh,   Is the MapGuide Server Service installed and running?
Sometimes it does not auto-start after install.   Bob
>  Sent: Saturday, March 25, 2006 5:38 PM
>  Cc: Dave Wilson
>  Dave/Others-
>  I am trying to install MapGuide OpenSource Web Server Extensions.
>  I tried it on Windows XP Professional on both ports- #8008 with MS4W
and #80 withOUT MS4W. I followed the instructions in
https://mapguide.osgeo.org/docs/InstallConfigureMapGuideOnWindows.pdf
for PHP. Then I tried logging-in to ../mapguide/mapadmin/login.php using
'Administrator' and 'admin' [case-sensitive] with both, Firefox and
Internet Explorer. This leads to an 'incorrect login' error. Apache
MapGuide service is running during these attempts.
>  I am now trying the same on Windows 2003 Professional Server.
>  Thanks, Harsh   -------- Original Message --------
>  From: "Dave Wilson" <dave.wilson at autodesk.com>
>  Date: Fri, March 24, 2006 7:02 pm
>  Could you kindly provide more details please?
>  For example are you logging into the Webadmin php page? For example
>  http://localhost:8008/mapguide/mapadmin/login.php for Apache.
>  Are you getting an error message if so what is it?.
>  Regards,
>  Dave
>  Sent: Friday, March 24, 2006 4:47 PM
>  Subject: [mapguide-users] login
>  username: Administrator
>  password: admin
>  ...do not work even when Apache MapGuide is running [WIN2003].
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
