[mapguide-users] PHP to ASP - dotnet namespace problems
Jason Birch
Jason.Birch at nanaimo.ca
Tue Mar 28 12:45:42 EST 2006
Grasping at straws here...
Have you tried doing a repair install on the web extensions? Go into
Add/Remove Programs, Click on "Change" and then select the repair
option.
Jason
From: Randy Glen Johnson [mailto:rjohnson at maintenanceconnection.com]
Sent: Tuesday, March 28, 2006 09:34
Subject: RE: [mapguide-users] PHP to ASP - dotnet namespace problems
Jason, I fixed the path as well as moved items around in the path,
rebooted, tested again and again, but nothing seems to fix that error.
Line 19 of the utilityfunctions.aspx is the line that is breaking...
<%@ Import Namespace="OSGeo.MapGuide" %>
is this a resource? Should I be looking at a specific file that has
this resource? And its path?
Best Regards,
Randy Glen Johnson
Programmer Analyst
Maintenance Connection, Inc.
1-888-567-3434 ext 800
http://www.maintenanceconnection.com
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060328/7ecf75fc/attachment.html
More information about the Mapguide-users
