[mapguide-users] Botched Install on IIS 6
Chris Tallman
ctallman at innomap.com
Fri Mar 31 15:04:19 EST 2006
Andy, & Jason.
Do you have two complete installs on MGO? One for development and one
open to the web? Are you just copying the repositories over when you
have created all the features?
I've been trying to create a front end back end setup with no luck.
Have you experimented with this type of setup?
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Friday, March 31, 2006 2:47 PM
Subject: [mapguide-users] Botched Install on IIS 6
Based on some discussions this morning, I changed a setting a in an IIS
6 / .NET web extensions install. This setting was to enable Integrated
Windows Authentication on the mapviewerajax virtual directory. I then
changed it back so it was not enabled. This was the only setting I
touched in the entire implementation. After this, I could no longer
login to the site via Studio, but could through the PHP Admin tool. I
tried using the repair option in the web extensions install, and that
did not help. I then uninstalled the web extensions entirely and
re-installed and got it working again. I confirmed that all of the
virtual directories had been removed from IIS by the uninstall prior to
reinstalling.
After the reinstall, here are some things I noticed that I had to
manually fix before it work:
* The mapviewerdwf virtual directory was not created
* The application name for the mapguide virtual directory was
mapagent
* The mapviewernet virtual directory was not configured as an
application
It looks like the installer has some major issues as others have noted
some of these problems with their installations as well.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com <http://www.SpatialGIS.com>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060331/3affcb24/attachment.html
More information about the Mapguide-users
