Failed Login
Amit Stein amitstein at gmail.com
Fri Mar 31 15:08:26 EST 2006
Hi!
I'm new with this program. I installed MapGuide Open Source in IIS and PHP
and I have problems login in. When I check the Web Extensions or the
MapGuide Server:
http://localhost/mapguide/mapagent/mapagent.fcgi?OPERATION=ENUMERATERESOURCES&VERSION=1.0.0&LOCALE=eng&RESOURCEID=Library://&TYPE=&DEPTH=-1
http://localhost/mapguide/mapviewerajax/ajaxviewer.php?WEBLAYOUT=Library://ATest.WebLayout
... the browser shows me the login's window, but when I login
user:"Administrator" pass:"admin" and click "OK", the same window shows up
again. I have the login window appearing in my screen all the time.
So I modified it: the function BuildViewer in mainframe.php
    else
        //HTML viewer enforce login here. DWF viewer enforces loggin
during the inital GETMAP request
        requestAuthentication();
        return;
with
    else
        $cred->SetMgUsernamePassword("Administrator", "admin");
Doing it this way I don't have problem, I can see the appropiate page ;)
However, I can't login in MapGuide Studio.
I don't have problem to login and navigate in
http://localhost/mapguide/mapadmin/login.php
I would like to be able to login in both the server and the studio without
having to make any modifications. Can you please help me with that?
Thanks!
Amit
More information about the Mapguide-users mailing list
