[mapguide-users] IIS Configuration of Mapguide OS - testing web server extensions fails
Andy Morsell
amorsell at spatialgis.com
Tue May 2 11:17:58 EDT 2006
It sounds like you are having the same problem a few of us experienced with
the latest build on Windows 2003. See this thread for the solution.
http://www.nabble.com/Win2003-fcgi-Install-Issue-and-Solution-t1414988.html#
a3813217
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
_____
From: Chris White [mailto:chris.white at keytraffic.com]
Sent: Tuesday, May 02, 2006 4:00 AM
Subject: [mapguide-users] IIS Configuration of Mapguide OS - testing web
I'm attempting to install MapGuide OS on Windows 2003 Server IIS 6. I have
followed the instructions in the 'Installing and Configuring on Windows'
document and the Map Agent test and Site Administrator test both are fine.
However when I attempt the web server extension test with the following url:
http://localhost/mapguide/mapviewerajax/ajaxviewer.aspx?WEBLAYOUT=Library://
ATest.WebLayout
I get the following IIS error
The page cannot be found
The page you are looking for might have been removed, had its name changed,
or is temporarily unavailable.
_____
Please try the following:
* Make sure that the Web site address displayed in the address bar of
your browser is spelled and formatted correctly.
* If you reached this page by clicking a link, contact the Web site
administrator to alert them that the link is incorrectly formatted.
* Click the Back <javascript:history.back(1)> button to try another
link.
HTTP Error 404 - File or directory not found.
Internet Information Services (IIS)
_____
Technical Information (for support personnel)
* Go to Microsoft Product
<http://go.microsoft.com/fwlink/?linkid=8180> Support Services and perform a
title search for the words HTTP and 404.
* Open IIS Help, which is accessible in IIS Manager (inetmgr), and
search for topics titled Web Site Setup, Common Administrative Tasks, and
About Custom Error Messages.
Any ideas? I previously installed on Windows XP without a problem. Could it
anything to do with the application protection for the mapagent (see page 16
of installation guide) as this is not an option with IIS 6?
Thanks in advance,
Chris
Chris White
Software Architect
_____
Key Traffic Systems Ltd.
Ardencroft Court
Ardens Grafton
Alcester
Warwickshire
B49 6DP
Main: +44(0)8451 303040
Fax: +44(0)8451 303141
<mailto:%20chris.white at keytraffic.com> Mailto: chris.white at keytraffic.com
Web: <http://www.keytraffic.com/> www.keytraffic.com
This e-mail & any attachments are intended only for the use of the person(s)
to whom it is addressed. It may contain information that is privileged and
confidential within the meaning of applicable law. If you are not the
intended recipient, please contact the sender as soon as possible by return
mail or Tel +44 (0) 8451 303040. The views expressed in this communication
may not necessarily be the views held by Key Traffic Systems Ltd.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060502/56dd27ac/attachment.html
More information about the Mapguide-users
