[mapguide-users] Buffer tool in the AJAX viewer
Butler, Juan P
jpbutler at co.pinellas.fl.us
Wed May 3 11:31:30 EDT 2006
I'm running Windows XP.
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Wednesday, May 03, 2006 11:29 AM
Subject: RE: [mapguide-users] Buffer tool in the AJAX viewer
No, they are both running the same build: MapGuide Server (Version
1.0.0.16802).
For what it's worth, the machine it works on with Sheboygan is the Win
2000 box. The application it does not work on in either case is using
the WA State Plane, North Zone, NAD83, feet coordinate system.
Andy
From: Traian Stanev [mailto:traian.stanev at autodesk.com]
Sent: Wednesday, May 03, 2006 8:19 AM
For your Sheboygan sample, do your two machines perhaps have different
builds of MapGuide on them?
Traian
Sent: Wednesday, May 03, 2006 11:15 AM
On both of my installs (one XP, one Win 2000, both .NET) with my
application, whenever I try to do a buffer, I get this error after
hitting the Done button: "Attempted to read or write protected memory.
This is often an indication that other memory is corrupt".
With the sample Sheboygan application running on the same machines, I
see the exact same symptoms you describe below on one machine, but it
works as expected on the other.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
Sent: Tuesday, May 02, 2006 9:14 PM
Subject: [mapguide-users] Buffer tool in the AJAX viewer
Has anyone been able to get the buffering to work in the AJAX viewer.
No matter what value I put in the distance and no matter what unit of
measure I choose, it just makes the same big red buffer that takes up
the whole map. Does this not work in the AJAX viewer?
- Juan
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060503/cf984f8e/attachment.html
More information about the Mapguide-users
