[mapguide-users] Sample application in PHP - HELP
Dimitrios Fryganiotis
dimitrios.fryganiotis at nsl.eu.com
Thu May 4 11:28:05 EDT 2006
Andy,
I don't have Mapguide Studio in order to create this MGP package. But I
know that the MGP file is simply a .zip file which contains XML files
and data, SDF files or images. I have loaded my package through the
Admin page successfully without errors. Is there any other way to create
an MGP file?
Dimitrios
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: 04 May 2006 16:19
Subject: RE: [mapguide-users] Sample application in PHP - HELP
It sounds to me like you are not using Studio to load your data or
create packages. Instead, you are reverse engineering the sample
package MGP and it's contained XML files and then editing those XML
files directly? Try loading some data through Studio, either directly
or by creating packages there and then loading them through Admin, to
see if that gets you further.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
From: Dimitrios Fryganiotis [mailto:dimitrios.fryganiotis at nsl.eu.com]
Sent: Thursday, May 04, 2006 8:11 AM
Subject: [mapguide-users] Sample application in PHP - HELP
Hello,
I am trying to create a very simple application in PHP which basically
is going to
plot a UK-IRELAND-FRANCE map using SDF 3.0 data. I am getting this data
initially
from an SHP file and then converting them using FME to SDF. As a basis
of my sample
I use the phpsample that is available from the website. So, I create the
XML files and then
together with the SDFs I create the MGP file. I load that package to the
server and then I try
to view the page, but no map is displayed on the screen, nothing. I
think the data are correct
since I can view them clearly using the FME viewer as SDF 3. It might
have to do with some sort
of scaling that i have to apply like in the parameters <Extends> and
<Bounds> in some of the XML files.
I have attached my package as zip file, please if somebody could try it
to see if it works I would highly
appreciate it. Also if someone knows how to create a simple demo in PHP
and few dummy data please
email me your demo. Thank you in advance.
Dimitrios
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060504/edb83f47/attachment.html
More information about the Mapguide-users
