[mapguide-users] Installing mapguide
Jason Birch
Jason.Birch at nanaimo.ca
Thu May 4 15:33:26 EDT 2006
Autodesk alluded to a PostGIS provider at one point, but I think that
they were unable to produce it initially because of limited internal
resources.
Are there any developers interested in doing this independently? Is
there enough interest for this on the list that we could come up with
some kind of collective effort to pay Refractions (or someone else) to
develop a PostGIS FDO provider? I guess that an OGR FDO provider
would also make sense, but having two levels of abstraction kind-of
makes my head spin.
It's hard to push this right now, because MapGuide isn't being used for
many production front end interfaces yet.
Jason
-----Original Message-----
From: Javier de la Torre [mailto:jatorre at gmail.com]
Sent: Thursday, May 04, 2006 11:30
Subject: Re: [mapguide-users] Installing mapguide
By the way...
I looked around and did not find a PostGIS FDO Provider.. what a pitty!
Is there any plan of creating one? Is there anybody working on this?
Thanks.
Javier.
On 5/4/06, Javier de la Torre <jatorre at gmail.com> wrote:
> I am loading lot of data in a PostGIS database so I am bored :)
> I tried modifying this as you said and now I got a different error...
> I could try to upgrade to gcc 4 but this is hard, this is a
> dependencies nightmare...
> For your info this is the error I get now:
> de-1.0.0/Server/src/UnitTesting/.libs
> /usr/bin/ld: cannot find -lACE
> collect2: ld returned 1 exit status
> make[3]: *** [mgserver] Error 1
> make[3]: Leaving directory
> `/root/mapguide_install/mapguide-1.0.0/Server/src/Core'
> make[2]: *** [all-recursive] Error 1
> make[2]: Leaving directory
`/root/mapguide_install/mapguide-1.0.0/Server/src'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory
`/root/mapguide_install/mapguide-1.0.0/Server'
> make: *** [all-recursive] Error 1
> On 5/4/06, Traian Stanev <traian.stanev at autodesk.com> wrote:
> > OK. This more or less matches what I was seeing -- I was trying to
> > compile on gentoo with gcc 3.4 yesterday. It has to do with some
> > templates in the ACE component. If I fix it I will send you the
> > patch needed to the ACE global header.
> > If you are feeling bored until then, you could try opening
> > ./Oem/ACE/ACE_wrappers/ace/Global_Macros.h and replace the two
> > occurences of (__GNUC__ >= 4) by (__GNUC__ >= 3). However, I am not
> > sure this is sufficient, since I haven't gotten through the whole
> > ACE build successfully yet.
> > Or you could try a different version of gcc but that's probably more
> > painful if you don't have one installed already.
> > Traian
> > Sent: Thursday, May 04, 2006 1:35 PM
> > gcc (GCC) 3.4.4 20050721 (Red Hat 3.4.4-2)
> > > I think I have seen this problem before. What version of gcc are
> > > you using?
> > > Sent: Thursday, May 04, 2006 1:03 PM
> > > Ok... I hope this is enough:
> > > make[2]: Entering directory
> > > `/root/mapguide_install/mapguide-1.0.0/Common/Service'
> > > if /bin/sh ../../libtool --mode=compile --tag=CXX g++
> > > -DPACKAGE_NAME=\"mapguide\" -DPACKAGE_TARNAME=\"mapguide\"
> > > -DPACKAGE_VERSION=\"1.0.0\" -DPACKAGE_STRING=\"mapguide\ 1.0.0\"
> > > -DPACKAGE_BUGREPORT=\"http://www.mapguide.osgeo.org\"
> > > -DPACKAGE=\"mapguide\" -DVERSION=\"1.0.0\" -DSTDC_HEADERS=1
> > > -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1
> > > -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1
> > > -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1
> > > -DHAVE_DLFCN_H=1 -DSTDC_HEADERS=1 -DHAVE_UNISTD_H=1
> > > -DHAVE_MATH_H=1
> > > -DHAVE_NETDB_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_SYS_TYPES_H=1
> > > -DHAVE_SYS_SOCKET_H=1 -DHAVE_GETHOSTBYNAME=1 -DHAVE_SOCKET=1
> > > -DHAVE_HTONS=1 -DHAVE_CONNECT=1 -DHAVE_SHUTDOWN=1 -I. -I.
> > > -IController -ICoordinateSystem -IData -IException -IGeometry
> > > -IMapLayer -INet -IServices -ISystem -IUtil -I../Security
> > > -I../MdfParser -I../MdfModel -I../../Oem/ACE/ACE_wrappers
> > > -I../../Oem/geos-2.2.0/source/headers
> > > -I../../Oem/dbxml-2.2.13/xerces-c-src/src
> > > -I../../Oem/proj-4.4.9/src -I../../Oem/gdal-1.3.0/ogr
-I../../Oem/gdal-1.3.0/port
> > > -I../../Common/CoordinateSystem -g -D_DEBUG -MT
> > > ServiceControllerBuild.lo -MD -MP -MF
> > > ".deps/ServiceControllerBuild.Tpo" -c -o ServiceControllerBuild.lo
> > > `test -f 'Controller/ServiceControllerBuild.cpp' || echo
> > > './'`Controller/ServiceControllerBuild.cpp; \ then mv -f
> > > ".deps/ServiceControllerBuild.Plo"; else rm -f
> > > ".deps/ServiceControllerBuild.Tpo"; exit 1; fi g++
> > > -DPACKAGE_VERSION=\"1.0.0\" "-DPACKAGE_STRING=\"mapguide 1.0.0\""
> > > -DHAVE_MATH_H=1
> > > -I../../Oem/gdal-1.3.0/port -I../../Common/CoordinateSystem -g
> > > -D_DEBUG -MT ServiceControllerBuild.lo -MD -MP -MF
> > > .deps/ServiceControllerBuild.Tpo -c
> > > Controller/ServiceControllerBuild.cpp -fPIC -DPIC -o
> > > .libs/ServiceControllerBuild.o In file included from
> > > ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.h:940,
> > > from
> > ../../Oem/ACE/ACE_wrappers/ace/Strategies_T.h:18,
> > > from
../../Oem/ACE/ACE_wrappers/ace/Acceptor.h:24,
> > > from ./AceCommon.h:56,
> > > from Controller/Controller.cpp:18,
> > > from Controller/ServiceControllerBuild.cpp:18:
> > > ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp: In member
> > > function `int ACE_Hash_Map_Manager_Ex<EXT_ID, INT_ID, HASH_KEY,
> > > COMPARE_KEYS, ACE_LOCK>::close_i()':
> > > ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp:158: error:
> > > expected class-name before '(' token
> > > COMPARE_KEYS, ACE_LOCK>::unbind_all_i()':
> > > ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp:190: error:
> > > COMPARE_KEYS, ACE_LOCK>::unbind_i(ACE_Hash_Map_Entry<EXT_ID,
> > > INT_ID>*)':
> > > ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp:289: error:
> > > expected class-name before '(' token In file included from
> > > ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.h:286,
> > > from
> > > ../../Oem/ACE/ACE_wrappers/ace/Thread_Manager.h:26,
> > > from
> > ../../Oem/ACE/ACE_wrappers/ace/Strategies_T.h:25,
> > > from
> > > ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp: In member
> > > function `void ACE_Unbounded_Queue<T>::delete_nodes()':
> > > ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp:133: error:
> > > ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp: In destructor
> > > `ACE_Unbounded_Queue<T>::~ACE_Unbounded_Queue()':
> > > ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp:153: error:
> > > function `int ACE_Unbounded_Queue<T>::dequeue_head(T&)':
> > > ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp:223: error:
> > > ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.h:307,
> > > from
> > ../../Oem/ACE/ACE_wrappers/ace/Containers_T.h:34,
> > > from
../../Oem/ACE/ACE_wrappers/ace/Containers.h:69,
> > > from
> > > ../../Oem/ACE/ACE_wrappers/ace/Thread_Manager.h:27,
> > > from
> > > from
> > > ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp: In member
> > > function `void ACE_Unbounded_Set<T>::delete_nodes()':
> > > ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp:107: error:
> > > ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp: In destructor
> > > `ACE_Unbounded_Set<T>::~ACE_Unbounded_Set()':
> > > ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp:126: error:
> > > function `int ACE_Unbounded_Set<T>::remove(const T&)':
> > > ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp:230: error:
> > > ../../Oem/ACE/ACE_wrappers/ace/Containers_T.h:1986,
> > > from
> > > from
> > > from
> > > from
> > > ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp: In member
> > > function `void ACE_Unbounded_Stack<T>::delete_all_nodes()':
> > > ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:171: error:
> > > ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp: In destructor
> > > `ACE_Unbounded_Stack<T>::~ACE_Unbounded_Stack()':
> > > ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:239: error:
> > > function `int ACE_Unbounded_Stack<T>::pop(T&)':
> > > ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:275: error:
> > > function `int ACE_Unbounded_Stack<T>::remove(const T&)':
> > > ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:334: error:
> > > function `int ACE_Ordered_MultiSet<T>::remove(const T&)':
> > > ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:1582: error:
> > > function `void ACE_Ordered_MultiSet<T>::delete_nodes()':
> > > ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:1786: error:
> > > make[2]: *** [ServiceControllerBuild.lo] Error 1
> > > make[1]: *** [check-recursive] Error 1
> > > `/root/mapguide_install/mapguide-1.0.0/Common'
> > > make: *** [check-recursive] Error 1
> > > On 5/4/06, Walt Welton-Lair <walt.welton-lair at autodesk.com> wrote:
> > > > You need to show us more of the error trace...
> > > > Sent: Thursday, May 04, 2006 12:58 PM
> > > > Ups...
> > > > Now it fails somehwere else. Now I get this at the end of "make"
> > > > Any idea of what can this be?
> > > > Thanks.
> > > > > Thanks all,
> > > > > I finally did a yum install libjpeg-devel and this installed
> > > > > the requiered libraries.
> > > > > Seems that I passed this step now :)
> > > > > It could be interesting to include in the documentation that
> > > > > the package that is needed is libjpeg-devel. Most people can
> > > > > then do a up2date or yum or apt-get to install it easily.
> > > > > Thanks again.
> > > > > Javier.
> > > > > On 5/4/06, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
> > > > > > You might have to specify --enable-shared as an input to the
> > > > configure
> > > > > > script.
> > > > > > Jason
> > > > > > Sent: Thursday, May 04, 2006 09:36
> > > > > > no, there is nothing there...
> > > > > > Am I installing the correct library? In the documentation it
> > says:
> > > > > > The libjpeg.so library is required. It is installed by
> > > > > > default
> > > with
> > > > most
> > > > > > Linux distributions. If you do not have it, you can download
> > > > > > the
> > > > source
> > > > > > from the Independent JPEG Group: www.ijg.org.
> > > > > > I downloaded from there:
> > > > > > http://www.ijg.org/files/jpegsrc.v6b.tar.gz
> > > > > > Now I am not sure...
> > > > > > JAvier.
> > > > > > > Did it put it under /usr/local/include by any chance?
> > > > > > > Sent: Thursday, May 04, 2006 12:23 PM
> > > > > > > Yes, I was logged as root.
> > > > > > > The file /usr/include/jpeglib.h does not exist.
> > > > > > > I downloaded the jpeg-6b and installed it but does not
> > > > > > > seems
> > to
> > > > > > > include this file. It copies others to usr/local/bin.
> > > > > > > Thanks.
wrote:
> > > > > > > > Were you logged in as root when you did make install? Do
> > > > > > > > you
> > > > have
> > > > > > > > jpeg installed (i.e. does /usr/include/jpeglib.h exist)?
> > > > > > > > Traian
> > > > > > > > Sent: Thursday, May 04, 2006 12:09 PM
> > > > > > > > Subject: [mapguide-users] Installing mapguide
> > > > > > > > Hi,
> > > > > > > > I am installing mapguide right now, but I am having some
> > > > problems
> > > > > > > > following the instructions on the PDF file.
> > > > > > > > I am trying to use all the default settings on an Intel
> > > > > > > > with
> > > Red
> > > > Hat
> > > > > > > 9.
> > > > > > > > First I installed Apache, Tomcat and PHP (APT) using the
> > > > provided
> > > > > > > > package. Everything seems to be fine, the servers are
> > > available
> > > > and
> > > > > > > > everyhting worked fine.
> > > > > > > > Then I download the Mapguide server an Mapguider server
> > > > extensions
> > > > > > > > and I build the OEMcomponents. This also seems to
> > > > > > > > compile
> > > fine.
> > > > > > > > IMake 1.0: Build Successful ........................
> > > > > > > > Done building OEM components .......................
> > > > > > > > Then I go and try to build and install the default
> > > > configuration:
> > > > > > > > aclocal I get this:
> > > > > > > > acinclude.m4:7: warning: underquoted definition of
> > > > MAP_HELP_STRING
> > > > > > > > run info '(automake)Extending aclocal'
> > > > > > > > or see
> > > > http://sources.redhat.com/automake/automake.html#Extending-acloc
> > > > al
> > > > > > > > acinclude.m4:12: warning: underquoted definition of
> > MAP_SUBST
> > > > > > > > acinclude.m4:19: warning: underquoted definition of
> > > > MAP_FAST_OUTPUT
> > > > > > > > acinclude.m4:25: warning: underquoted definition of
> > > > > > > MAP_GEN_CONFIG_VARS
> > > > > > > > acinclude.m4:67: warning: underquoted definition of
> > > > > > > > MAP_GENERATE_MAKEFILES
> > > > > > > > acinclude.m4:74: warning: underquoted definition of
> > MAP_OUTPUT
> > > > > > > > acinclude.m4:83: warning: underquoted definition of
> > > > > > > > MAP_DEFINE_TYPE_RLIM_T
> > > > > > > > acinclude.m4:108: warning: underquoted definition of
> > > > > > > > MAP_SUBST_EXPANDED_ARG
> > > > > > > > acinclude.m4:115: warning: underquoted definition of
> > > > > > > > MAP_EXPORT_ARGUMENTS
> > > > > > > > libtoolize --force OK
> > > > > > > > automake --add-missing --copy OK
> > > > > > > > autoconf OK
> > > > > > > > ./configure OK
> > > > > > > > make OK
> > > > > > > > make check OK
> > > > > > > > make install get into troubles... After lot of messages
> > > > > > > > I
> > > start
> > > > > > > > getting errors, this is the first one:
> > > > > > > > BOpcodeHandler.cpp:52:29: jpeglib.h: No such file or
> > directory
> > > > > > > > BOpcodeHandler.cpp:4970: error: field `jerr' has
> > > > > > > > incomplete
> > > type
> > > > > > > > And I can not continue following the instructions :(
> > > > > > > > Anybody can help?
> > > > > > > > Thanks in advance.
> > > > > > > > Javier.
> > > > > > > > - To unsubscribe, e-mail:
> > users-unsubscribe at mapguide.osgeo.org
> > > > > > > > For additional commands, e-mail:
> > users-help at mapguide.osgeo.org
> > > > > > To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> > > > For additional commands, e-mail: users-help at mapguide.osgeo.org
> > > --- To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
More information about the Mapguide-users
