[mapguide-users] Installing mapguide
Javier de la Torre
jatorre at gmail.com
Fri May 5 09:23:19 EDT 2006
Sorry again,
But I managed to make it run :)
I added /usr/local/pgsql/lib to the /etc/ld.so.conf and reruned ldconfig
Now it is started...
I can start playing!
Thanks again for your support.
Javier.
On 5/5/06, Javier de la Torre <jatorre at gmail.com> wrote:
> Ohh! As you said...
> libpq is a PostgreSQL library. I have it in /usr/local/pgsql/lib/libpq.so.4
> Could it be that mapguide can not find it because is not a shared
> library? Why is mapguide trying to use it?
> When I did the configure in the report at the end I got:
> POSTGRESQL support: yes
> So seems that is looking for it...
> Any idea on how can I solve this?
> Javi.
> > Ok... Now it seems that I got it fine until the "make check" where it
> > proposes to report here.
> > This is what I got when I did "make"
> > (cd .libs && rm -f libMapGuideJavaApi.la && ln -s
> > ../libMapGuideJavaApi.la libMapGuideJavaApi.la)
> > make[4]: Leaving directory
> > `/root/mapguide_install/mapguide-1.0.0/Web/src/JavaApi'
> > make[3]: Leaving directory
> > make[3]: Entering directory `/root/mapguide_install/mapguide-1.0.0/Web/src'
> > make[3]: Nothing to be done for `all-am'.
> > make[3]: Leaving directory `/root/mapguide_install/mapguide-1.0.0/Web/src'
> > make[2]: Leaving directory `/root/mapguide_install/mapguide-1.0.0/Web/src'
> > make[2]: Entering directory `/root/mapguide_install/mapguide-1.0.0/Web'
> > make[2]: Nothing to be done for `all-am'.
> > make[2]: Leaving directory `/root/mapguide_install/mapguide-1.0.0/Web'
> > make[1]: Leaving directory `/root/mapguide_install/mapguide-1.0.0/Web'
> > make[1]: Entering directory `/root/mapguide_install/mapguide-1.0.0'
> > make[1]: Nothing to be done for `all-am'.
> > make[1]: Leaving directory `/root/mapguide_install/mapguide-1.0.0'
> > [root at synthesys mapguide-1.0.0]#
> > Doesn't seem to have any error, but it also doesn't look like a great success :)
> > Then I do the make check and this is the result:
> > Making check in Core
> > `/root/mapguide_install/mapguide-1.0.0/Server/src/Core'
> > make check-TESTS
> > make[4]: Entering directory
> > GDAL_DATA=/root/mapguide_install/mapguide-1.0.0/Oem/gdal-1.3.0/data
> > PROJ_LIB=/root/mapguide_install/mapguide-1.0.0/Oem/proj-4.4.9/nad
> > /root/mapguide_install/mapguide-1.0.0/Server/src/Core/.libs/lt-mgserver:
> > error while loading shared libraries: libpq.so.4: cannot open shared
> > object file: No such file or directory
> > FAIL: unittest.sh
> > 1 of 1 tests failed
> > Please report to http://www.mapguide.osgeo.org
> > make[4]: *** [check-TESTS] Error 1
> > make[3]: *** [check-am] Error 2
> > make[2]: *** [check-recursive] Error 1
> > make[2]: Leaving directory `/root/mapguide_install/mapguide-1.0.0/Server/src'
> > make[1]: *** [check-recursive] Error 1
> > make[1]: Leaving directory `/root/mapguide_install/mapguide-1.0.0/Server'
> > make: *** [check-recursive] Error 1
> > If I do a a make install seems to work but when running the server I
> > get the same error (that seems to be detected by make check) with the
> > libpq.so.4 library missing.
> > When I run ldd mgserver the only missing library seems to be
> > libpq.so.4 => not found (or at least this is where it stops)
> > I will try to find the library...
> > Thanks.
> > Javier.
> > > Sorry,
> > > I had to start from scratch again :(
> > > By the way, the build_apt script does not work when using a different
> > > prefix. For example this:
> > > ./build_apt.sh -prefix /usr/local/servers -port 80 -with-tomcat
> > > compiles fine but at the end Apache doe snot start because:
> > > "Bringing Apache online...
> > > /usr/local/servers/webserverextensions/apache2/bin ~/mapguide_install/LinuxApt
> > > httpd: could not open document config file
> > > /usr/local/mapguideopensource/webserverextensions/apache2/conf/httpd.conf"
> > > So, seems that in the build file does not replace the
> > > mapguideopensource prefix somewhere needed by apache.
> > > I will run it on the default so is no problem for me.
> > > Javier.
> > > On 5/5/06, Traian Stanev <traian.stanev at autodesk.com> wrote:
> > > > Hmm, I don't think we build that library so it probably won't make a difference -- it's a PostgreSQL library and I'm not sure why it needs it... Could you run "ldd mgserver" and see what other libraries it is complaining about.
> > > > Traian
> > > > -----Original Message-----
> > > > From: Javier de la Torre [mailto:jatorre at gmail.com]
> > > > Sent: Fri 5/5/2006 5:38 AM
> > > > To: users at mapguide.osgeo.org
> > > > Cc:
> > > > Subject: Re: [mapguide-users] Installing mapguide
> > > > HI Trian,
> > > > Today I tried to start from scratch again with the modifications that
> > > > you gave me yesterday.
> > > > I manage to make and make install this time, but I believe there were
> > > > some errors (sorry I was not there when it executed and it was in a
> > > > batch...).
> > > > After doing the make / make install I tried to run mgserver.sh and
> > > > this is what I got:
> > > > [root at synthesys bin]# ./mgserver.sh
> > > > /usr/local/mapguideopensource/server/bin /usr/local/
> > > > ./mgserver: error while loading shared libraries: libpq.so.4: cannot
> > > > open shared object file: No such file or directory
> > > > So this is probably because there were some errors in the building no?
> > > > I will try the whole process again, but this time I will check if it
> > > > fails somewhere in the process.
> > > > Javier.
> > > > On 04/05/2006, at 20:29, Traian Stanev wrote:
> > > > > Looks like it's still complaining about ACE. Actually, ACE is supposed
> > > > > to build as part of the build_oem.sh script. However, when you ran
> > > > > build_oem.sh, ACE probably failed but did not exit the script (the
> > > > > script in the released tar has that problem), so it was really broken
> > > > > from the start. I don't know how much this has messed up the build
> > > > > environment, so what I would do is to clean out the mapguide-1.0.0
> > > > > directory completely, unzip the mapguide source again, then apply this
> > > > > change *before* building anything.
> > > > > Traian
> > > > > Sent: Thursday, May 04, 2006 2:16 PM
> > > > > I am loading lot of data in a PostGIS database so I am bored :)
> > > > > I tried modifying this as you said and now I got a different error...
> > > > > I could try to upgrade to gcc 4 but this is hard, this is a
> > > > > dependencies nightmare...
> > > > > For your info this is the error I get now:
> > > > > de-1.0.0/Server/src/UnitTesting/.libs
> > > > > /usr/bin/ld: cannot find -lACE
> > > > > collect2: ld returned 1 exit status
> > > > > make[3]: *** [mgserver] Error 1
> > > > > make[2]: *** [all-recursive] Error 1
> > > > > make[1]: *** [all-recursive] Error 1
> > > > > make: *** [all-recursive] Error 1
> > > > > On 5/4/06, Traian Stanev <traian.stanev at autodesk.com> wrote:
> > > > >> OK. This more or less matches what I was seeing -- I was trying to
> > > > >> compile on gentoo with gcc 3.4 yesterday. It has to do with some
> > > > >> templates in the ACE component. If I fix it I will send you the patch
> > > > >> needed to the ACE global header.
> > > > >> If you are feeling bored until then, you could try opening
> > > > >> ./Oem/ACE/ACE_wrappers/ace/Global_Macros.h and replace the two
> > > > >> occurences of (__GNUC__ >= 4) by (__GNUC__ >= 3). However, I am not
> > > > > sure
> > > > >> this is sufficient, since I haven't gotten through the whole ACE
> > > > >> build
> > > > >> successfully yet.
> > > > >> Or you could try a different version of gcc but that's probably more
> > > > >> painful if you don't have one installed already.
> > > > >> Traian
> > > > >> Sent: Thursday, May 04, 2006 1:35 PM
> > > > >> gcc (GCC) 3.4.4 20050721 (Red Hat 3.4.4-2)
> > > > >>> I think I have seen this problem before. What version of gcc are you
> > > > >>> using?
> > > > >>> Sent: Thursday, May 04, 2006 1:03 PM
> > > > >>> Ok... I hope this is enough:
> > > > >>> `/root/mapguide_install/mapguide-1.0.0/Common/Service'
> > > > >>> if /bin/sh ../../libtool --mode=compile --tag=CXX g++
> > > > >>> -DPACKAGE_NAME=\"mapguide\" -DPACKAGE_TARNAME=\"mapguide\"
> > > > >>> -DPACKAGE_VERSION=\"1.0.0\" -DPACKAGE_STRING=\"mapguide\ 1.0.0\"
> > > > >>> -DPACKAGE_BUGREPORT=\"http://www.mapguide.osgeo.org\"
> > > > >>> -DPACKAGE=\"mapguide\" -DVERSION=\"1.0.0\" -DSTDC_HEADERS=1
> > > > >>> -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1
> > > > >>> -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1
> > > > >>> -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1
> > > > >>> -DHAVE_DLFCN_H=1 -DSTDC_HEADERS=1 -DHAVE_UNISTD_H=1 -DHAVE_MATH_H=1
> > > > >>> -DHAVE_NETDB_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_SYS_TYPES_H=1
> > > > >>> -DHAVE_SYS_SOCKET_H=1 -DHAVE_GETHOSTBYNAME=1 -DHAVE_SOCKET=1
> > > > >>> -DHAVE_HTONS=1 -DHAVE_CONNECT=1 -DHAVE_SHUTDOWN=1 -I. -I.
> > > > >>> -IController -ICoordinateSystem -IData -IException -IGeometry
> > > > >>> -IMapLayer -INet -IServices -ISystem -IUtil -I../Security
> > > > >>> -I../MdfParser -I../MdfModel -I../../Oem/ACE/ACE_wrappers
> > > > >>> -I../../Oem/geos-2.2.0/source/headers
> > > > >>> -I../../Oem/dbxml-2.2.13/xerces-c-src/src -I../../Oem/proj-4.4.9/src
> > > > >>> -I../../Oem/gdal-1.3.0/ogr -I../../Oem/gdal-1.3.0/port
> > > > >>> -I../../Common/CoordinateSystem -g -D_DEBUG -MT
> > > > >>> ServiceControllerBuild.lo -MD -MP -MF
> > > > >>> ".deps/ServiceControllerBuild.Tpo" -c -o ServiceControllerBuild.lo
> > > > >>> `test -f 'Controller/ServiceControllerBuild.cpp' || echo
> > > > >>> './'`Controller/ServiceControllerBuild.cpp; \
> > > > >>> then mv -f ".deps/ServiceControllerBuild.Tpo"
> > > > >>> ".deps/ServiceControllerBuild.Plo"; else rm -f
> > > > >>> ".deps/ServiceControllerBuild.Tpo"; exit 1; fi
> > > > >>> g++ -DPACKAGE_NAME=\"mapguide\" -DPACKAGE_TARNAME=\"mapguide\"
> > > > >>> -DPACKAGE_VERSION=\"1.0.0\" "-DPACKAGE_STRING=\"mapguide 1.0.0\""
> > > > > -IController
> > > > >>> -ICoordinateSystem -IData -IException -IGeometry -IMapLayer -INet
> > > > >>> -IServices -ISystem -IUtil -I../Security -I../MdfParser
> > > > > -I../MdfModel
> > > > >>> -I../../Oem/ACE/ACE_wrappers -I../../Oem/geos-2.2.0/source/headers
> > > > >>> -c Controller/ServiceControllerBuild.cpp -fPIC -DPIC -o
> > > > >>> .libs/ServiceControllerBuild.o
> > > > >>> In file included from
> > > > >>> ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.h:940,
> > > > >>> from
> > > > >> ../../Oem/ACE/ACE_wrappers/ace/Strategies_T.h:18,
> > > > >>> from ../../Oem/ACE/ACE_wrappers/ace/Acceptor.h:24,
> > > > >>> from ./AceCommon.h:56,
> > > > >>> from Controller/Controller.cpp:18,
> > > > >>> from Controller/ServiceControllerBuild.cpp:18:
> > > > >>> ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp: In member
> > > > >>> function `int ACE_Hash_Map_Manager_Ex<EXT_ID, INT_ID, HASH_KEY,
> > > > >>> COMPARE_KEYS, ACE_LOCK>::close_i()':
> > > > >>> ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp:158: error:
> > > > >>> expected class-name before '(' token
> > > > >>> COMPARE_KEYS, ACE_LOCK>::unbind_all_i()':
> > > > >>> ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp:190: error:
> > > > >>> COMPARE_KEYS, ACE_LOCK>::unbind_i(ACE_Hash_Map_Entry<EXT_ID,
> > > > >>> INT_ID>*)':
> > > > >>> ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp:289: error:
> > > > >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.h:286,
> > > > >>> from
> > > > >>> ../../Oem/ACE/ACE_wrappers/ace/Thread_Manager.h:26,
> > > > >>> from
> > > > >> ../../Oem/ACE/ACE_wrappers/ace/Strategies_T.h:25,
> > > > >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp: In member
> > > > > function
> > > > >>> `void ACE_Unbounded_Queue<T>::delete_nodes()':
> > > > >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp:133: error:
> > > > >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp: In destructor
> > > > >>> `ACE_Unbounded_Queue<T>::~ACE_Unbounded_Queue()':
> > > > >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp:153: error:
> > > > > function
> > > > >>> `int ACE_Unbounded_Queue<T>::dequeue_head(T&)':
> > > > >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp:223: error:
> > > > >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.h:307,
> > > > >>> from
> > > > >> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.h:34,
> > > > >>> from
> > > > > ../../Oem/ACE/ACE_wrappers/ace/Containers.h:69,
> > > > >>> from
> > > > >>> ../../Oem/ACE/ACE_wrappers/ace/Thread_Manager.h:27,
> > > > >>> from
> > > > >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp: In member function
> > > > >>> `void ACE_Unbounded_Set<T>::delete_nodes()':
> > > > >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp:107: error:
> > > > > expected
> > > > >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp: In destructor
> > > > >>> `ACE_Unbounded_Set<T>::~ACE_Unbounded_Set()':
> > > > >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp:126: error:
> > > > > expected
> > > > >>> `int ACE_Unbounded_Set<T>::remove(const T&)':
> > > > >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp:230: error:
> > > > > expected
> > > > >>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.h:1986,
> > > > >>> from
> > > > >>> from
> > > > >>> from
> > > > >>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp: In member function
> > > > >>> `void ACE_Unbounded_Stack<T>::delete_all_nodes()':
> > > > >>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:171: error: expected
> > > > >>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp: In destructor
> > > > >>> `ACE_Unbounded_Stack<T>::~ACE_Unbounded_Stack()':
> > > > >>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:239: error: expected
> > > > >>> `int ACE_Unbounded_Stack<T>::pop(T&)':
> > > > >>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:275: error: expected
> > > > >>> `int ACE_Unbounded_Stack<T>::remove(const T&)':
> > > > >>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:334: error: expected
> > > > >>> `int ACE_Ordered_MultiSet<T>::remove(const T&)':
> > > > >>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:1582: error:
> > > > > expected
> > > > >>> `void ACE_Ordered_MultiSet<T>::delete_nodes()':
> > > > >>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:1786: error:
> > > > > expected
> > > > >>> make[2]: *** [ServiceControllerBuild.lo] Error 1
> > > > >>> `/root/mapguide_install/mapguide-1.0.0/Common'
> > > > >>> On 5/4/06, Walt Welton-Lair <walt.welton-lair at autodesk.com> wrote:
> > > > >>>> You need to show us more of the error trace...
> > > > >>>> Sent: Thursday, May 04, 2006 12:58 PM
> > > > >>>> Ups...
> > > > >>>> Now it fails somehwere else. Now I get this at the end of "make"
> > > > >>>> Any idea of what can this be?
> > > > >>>> Thanks.
> > > > >>>> On 5/4/06, Javier de la Torre <jatorre at gmail.com> wrote:
> > > > >>>>> Thanks all,
> > > > >>>>> I finally did a yum install libjpeg-devel and this installed the
> > > > >>>>> requiered libraries.
> > > > >>>>> Seems that I passed this step now :)
> > > > >>>>> It could be interesting to include in the documentation that the
> > > > >>>>> package that is needed is libjpeg-devel. Most people can then do
> > > > > a
> > > > >>>>> up2date or yum or apt-get to install it easily.
> > > > >>>>> Thanks again.
> > > > >>>>> Javier.
> > > > >>>>> On 5/4/06, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
> > > > >>>>>> You might have to specify --enable-shared as an input to the
> > > > >>>> configure
> > > > >>>>>> script.
> > > > >>>>>> Jason
> > > > >>>>>> Sent: Thursday, May 04, 2006 09:36
> > > > >>>>>> no, there is nothing there...
> > > > >>>>>> Am I installing the correct library? In the documentation it
> > > > >> says:
> > > > >>>>>> The libjpeg.so library is required. It is installed by default
> > > > >>> with
> > > > >>>> most
> > > > >>>>>> Linux distributions. If you do not have it, you can download
> > > > > the
> > > > >>>> source
> > > > >>>>>> from the Independent JPEG Group: www.ijg.org.
> > > > >>>>>> I downloaded from there:
> > > > >>>>>> http://www.ijg.org/files/jpegsrc.v6b.tar.gz
> > > > >>>>>> Now I am not sure...
> > > > >>>>>> JAvier.
> > > > >>>>>>> Did it put it under /usr/local/include by any chance?
> > > > >>>>>>> Sent: Thursday, May 04, 2006 12:23 PM
> > > > >>>>>>> Yes, I was logged as root.
> > > > >>>>>>> The file /usr/include/jpeglib.h does not exist.
> > > > >>>>>>> I downloaded the jpeg-6b and installed it but does not seems
> > > > >> to
> > > > >>>>>>> include this file. It copies others to usr/local/bin.
> > > > >>>>>>> Thanks.
> > > > >>>>>>>> Were you logged in as root when you did make install? Do
> > > > > you
> > > > >>>> have
> > > > >>>>>>>> jpeg installed (i.e. does /usr/include/jpeglib.h exist)?
> > > > >>>>>>>> Traian
> > > > >>>>>>>> Sent: Thursday, May 04, 2006 12:09 PM
> > > > >>>>>>>> Subject: [mapguide-users] Installing mapguide
> > > > >>>>>>>> Hi,
> > > > >>>>>>>> I am installing mapguide right now, but I am having some
> > > > >>>> problems
> > > > >>>>>>>> following the instructions on the PDF file.
> > > > >>>>>>>> I am trying to use all the default settings on an Intel
> > > > > with
> > > > >>> Red
> > > > >>>> Hat
> > > > >>>>>>> 9.
> > > > >>>>>>>> First I installed Apache, Tomcat and PHP (APT) using the
> > > > >>>> provided
> > > > >>>>>>>> package. Everything seems to be fine, the servers are
> > > > >>> available
> > > > >>>> and
> > > > >>>>>>>> everyhting worked fine.
> > > > >>>>>>>> Then I download the Mapguide server an Mapguider server
> > > > >>>> extensions
> > > > >>>>>>>> and I build the OEMcomponents. This also seems to compile
> > > > >>> fine.
> > > > >>>>>>>> IMake 1.0: Build Successful ........................
> > > > >>>>>>>> Done building OEM components .......................
> > > > >>>>>>>> Then I go and try to build and install the default
> > > > >>>> configuration:
> > > > >>>>>>>> aclocal I get this:
> > > > >>>>>>>> acinclude.m4:7: warning: underquoted definition of
> > > > >>>> MAP_HELP_STRING
> > > > >>>>>>>> run info '(automake)Extending aclocal'
> > > > >>>>>>>> or see
> > > > >>>> http://sources.redhat.com/automake/automake.html#Extending-aclocal
> > > > >>>>>>>> acinclude.m4:12: warning: underquoted definition of
> > > > >> MAP_SUBST
> > > > >>>>>>>> acinclude.m4:19: warning: underquoted definition of
> > > > >>>> MAP_FAST_OUTPUT
> > > > >>>>>>>> acinclude.m4:25: warning: underquoted definition of
> > > > >>>>>>> MAP_GEN_CONFIG_VARS
> > > > >>>>>>>> acinclude.m4:67: warning: underquoted definition of
> > > > >>>>>>>> MAP_GENERATE_MAKEFILES
> > > > >>>>>>>> acinclude.m4:74: warning: underquoted definition of
> > > > >> MAP_OUTPUT
> > > > >>>>>>>> acinclude.m4:83: warning: underquoted definition of
> > > > >>>>>>>> MAP_DEFINE_TYPE_RLIM_T
> > > > >>>>>>>> acinclude.m4:108: warning: underquoted definition of
> > > > >>>>>>>> MAP_SUBST_EXPANDED_ARG
> > > > >>>>>>>> acinclude.m4:115: warning: underquoted definition of
> > > > >>>>>>>> MAP_EXPORT_ARGUMENTS
> > > > >>>>>>>> libtoolize --force OK
> > > > >>>>>>>> automake --add-missing --copy OK
> > > > >>>>>>>> autoconf OK
> > > > >>>>>>>> ./configure OK
> > > > >>>>>>>> make OK
> > > > >>>>>>>> make check OK
> > > > >>>>>>>> make install get into troubles... After lot of messages I
> > > > >>> start
> > > > >>>>>>>> getting errors, this is the first one:
> > > > >>>>>>>> BOpcodeHandler.cpp:52:29: jpeglib.h: No such file or
> > > > >> directory
> > > > >>>>>>>> BOpcodeHandler.cpp:4970: error: field `jerr' has
> > > > > incomplete
> > > > >>> type
> > > > >>>>>>>> And I can not continue following the instructions :(
> > > > >>>>>>>> Anybody can help?
> > > > >>>>>>>> Thanks in advance.
> > > > >>>>>>>> Javier.
> > > > >>>>>>>> - To unsubscribe, e-mail:
> > > > >> users-unsubscribe at mapguide.osgeo.org
> > > > >>>>>>>> For additional commands, e-mail:
> > > > >> users-help at mapguide.osgeo.org
> > > > >>>>>>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> > > > >>>>>> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users
