[mapguide-users] Installing mapguide
Javier de la Torre
jatorre at gmail.com
Fri May 5 05:38:02 EDT 2006
HI Trian,
Today I tried to start from scratch again with the modifications that
you gave me yesterday.
I manage to make and make install this time, but I believe there were
some errors (sorry I was not there when it executed and it was in a
batch...).
After doing the make / make install I tried to run mgserver.sh and
this is what I got:
[root at synthesys bin]# ./mgserver.sh
/usr/local/mapguideopensource/server/bin /usr/local/
./mgserver: error while loading shared libraries: libpq.so.4: cannot
open shared object file: No such file or directory
So this is probably because there were some errors in the building no?
I will try the whole process again, but this time I will check if it
fails somewhere in the process.
Javier.
On 04/05/2006, at 20:29, Traian Stanev wrote:
> Looks like it's still complaining about ACE. Actually, ACE is supposed
> to build as part of the build_oem.sh script. However, when you ran
> build_oem.sh, ACE probably failed but did not exit the script (the
> script in the released tar has that problem), so it was really broken
> from the start. I don't know how much this has messed up the build
> environment, so what I would do is to clean out the mapguide-1.0.0
> directory completely, unzip the mapguide source again, then apply this
> change *before* building anything.
> Traian
> -----Original Message-----
> From: Javier de la Torre [mailto:jatorre at gmail.com]
> Sent: Thursday, May 04, 2006 2:16 PM
> To: users at mapguide.osgeo.org
> Subject: Re: [mapguide-users] Installing mapguide
> I am loading lot of data in a PostGIS database so I am bored :)
> I tried modifying this as you said and now I got a different error...
> I could try to upgrade to gcc 4 but this is hard, this is a
> dependencies nightmare...
> For your info this is the error I get now:
> de-1.0.0/Server/src/UnitTesting/.libs
> /usr/bin/ld: cannot find -lACE
> collect2: ld returned 1 exit status
> make[3]: *** [mgserver] Error 1
> make[3]: Leaving directory
> `/root/mapguide_install/mapguide-1.0.0/Server/src/Core'
> make[2]: *** [all-recursive] Error 1
> make[2]: Leaving directory
> `/root/mapguide_install/mapguide-1.0.0/Server/src'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory
> `/root/mapguide_install/mapguide-1.0.0/Server'
> make: *** [all-recursive] Error 1
> On 5/4/06, Traian Stanev <traian.stanev at autodesk.com> wrote:
>> OK. This more or less matches what I was seeing -- I was trying to
>> compile on gentoo with gcc 3.4 yesterday. It has to do with some
>> templates in the ACE component. If I fix it I will send you the patch
>> needed to the ACE global header.
>> If you are feeling bored until then, you could try opening
>> ./Oem/ACE/ACE_wrappers/ace/Global_Macros.h and replace the two
>> occurences of (__GNUC__ >= 4) by (__GNUC__ >= 3). However, I am not
> sure
>> this is sufficient, since I haven't gotten through the whole ACE
>> build
>> successfully yet.
>> Or you could try a different version of gcc but that's probably more
>> painful if you don't have one installed already.
>> Traian
>> Sent: Thursday, May 04, 2006 1:35 PM
>> gcc (GCC) 3.4.4 20050721 (Red Hat 3.4.4-2)
>>> I think I have seen this problem before. What version of gcc are you
>>> using?
>>> Sent: Thursday, May 04, 2006 1:03 PM
>>> Ok... I hope this is enough:
>>> make[2]: Entering directory
>>> `/root/mapguide_install/mapguide-1.0.0/Common/Service'
>>> if /bin/sh ../../libtool --mode=compile --tag=CXX g++
>>> -DPACKAGE_NAME=\"mapguide\" -DPACKAGE_TARNAME=\"mapguide\"
>>> -DPACKAGE_VERSION=\"1.0.0\" -DPACKAGE_STRING=\"mapguide\ 1.0.0\"
>>> -DPACKAGE_BUGREPORT=\"http://www.mapguide.osgeo.org\"
>>> -DPACKAGE=\"mapguide\" -DVERSION=\"1.0.0\" -DSTDC_HEADERS=1
>>> -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1
>>> -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1
>>> -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1
>>> -DHAVE_DLFCN_H=1 -DSTDC_HEADERS=1 -DHAVE_UNISTD_H=1 -DHAVE_MATH_H=1
>>> -DHAVE_NETDB_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_SYS_TYPES_H=1
>>> -DHAVE_SYS_SOCKET_H=1 -DHAVE_GETHOSTBYNAME=1 -DHAVE_SOCKET=1
>>> -DHAVE_HTONS=1 -DHAVE_CONNECT=1 -DHAVE_SHUTDOWN=1 -I. -I.
>>> -IController -ICoordinateSystem -IData -IException -IGeometry
>>> -IMapLayer -INet -IServices -ISystem -IUtil -I../Security
>>> -I../MdfParser -I../MdfModel -I../../Oem/ACE/ACE_wrappers
>>> -I../../Oem/geos-2.2.0/source/headers
>>> -I../../Oem/dbxml-2.2.13/xerces-c-src/src -I../../Oem/proj-4.4.9/src
>>> -I../../Oem/gdal-1.3.0/ogr -I../../Oem/gdal-1.3.0/port
>>> -I../../Common/CoordinateSystem -g -D_DEBUG -MT
>>> ServiceControllerBuild.lo -MD -MP -MF
>>> ".deps/ServiceControllerBuild.Tpo" -c -o ServiceControllerBuild.lo
>>> `test -f 'Controller/ServiceControllerBuild.cpp' || echo
>>> './'`Controller/ServiceControllerBuild.cpp; \
>>> then mv -f ".deps/ServiceControllerBuild.Tpo"
>>> ".deps/ServiceControllerBuild.Plo"; else rm -f
>>> ".deps/ServiceControllerBuild.Tpo"; exit 1; fi
>>> g++ -DPACKAGE_NAME=\"mapguide\" -DPACKAGE_TARNAME=\"mapguide\"
>>> -DPACKAGE_VERSION=\"1.0.0\" "-DPACKAGE_STRING=\"mapguide 1.0.0\""
> -IController
>>> -ICoordinateSystem -IData -IException -IGeometry -IMapLayer -INet
>>> -IServices -ISystem -IUtil -I../Security -I../MdfParser
> -I../MdfModel
>>> -I../../Oem/ACE/ACE_wrappers -I../../Oem/geos-2.2.0/source/headers
>>> -c Controller/ServiceControllerBuild.cpp -fPIC -DPIC -o
>>> .libs/ServiceControllerBuild.o
>>> In file included from
>>> ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.h:940,
>>> from
>> ../../Oem/ACE/ACE_wrappers/ace/Strategies_T.h:18,
>>> from ../../Oem/ACE/ACE_wrappers/ace/Acceptor.h:24,
>>> from ./AceCommon.h:56,
>>> from Controller/Controller.cpp:18,
>>> from Controller/ServiceControllerBuild.cpp:18:
>>> ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp: In member
>>> function `int ACE_Hash_Map_Manager_Ex<EXT_ID, INT_ID, HASH_KEY,
>>> COMPARE_KEYS, ACE_LOCK>::close_i()':
>>> ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp:158: error:
>>> expected class-name before '(' token
>>> COMPARE_KEYS, ACE_LOCK>::unbind_all_i()':
>>> ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp:190: error:
>>> COMPARE_KEYS, ACE_LOCK>::unbind_i(ACE_Hash_Map_Entry<EXT_ID,
>>> INT_ID>*)':
>>> ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp:289: error:
>>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.h:286,
>>> from
>>> ../../Oem/ACE/ACE_wrappers/ace/Thread_Manager.h:26,
>>> from
>> ../../Oem/ACE/ACE_wrappers/ace/Strategies_T.h:25,
>>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp: In member
> function
>>> `void ACE_Unbounded_Queue<T>::delete_nodes()':
>>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp:133: error:
>>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp: In destructor
>>> `ACE_Unbounded_Queue<T>::~ACE_Unbounded_Queue()':
>>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp:153: error:
> function
>>> `int ACE_Unbounded_Queue<T>::dequeue_head(T&)':
>>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp:223: error:
>>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.h:307,
>>> from
>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.h:34,
>>> from
> ../../Oem/ACE/ACE_wrappers/ace/Containers.h:69,
>>> from
>>> ../../Oem/ACE/ACE_wrappers/ace/Thread_Manager.h:27,
>>> from
>>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp: In member function
>>> `void ACE_Unbounded_Set<T>::delete_nodes()':
>>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp:107: error:
> expected
>>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp: In destructor
>>> `ACE_Unbounded_Set<T>::~ACE_Unbounded_Set()':
>>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp:126: error:
> expected
>>> `int ACE_Unbounded_Set<T>::remove(const T&)':
>>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp:230: error:
> expected
>>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.h:1986,
>>> from
>>> from
>>> from
>>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp: In member function
>>> `void ACE_Unbounded_Stack<T>::delete_all_nodes()':
>>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:171: error: expected
>>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp: In destructor
>>> `ACE_Unbounded_Stack<T>::~ACE_Unbounded_Stack()':
>>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:239: error: expected
>>> `int ACE_Unbounded_Stack<T>::pop(T&)':
>>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:275: error: expected
>>> `int ACE_Unbounded_Stack<T>::remove(const T&)':
>>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:334: error: expected
>>> `int ACE_Ordered_MultiSet<T>::remove(const T&)':
>>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:1582: error:
> expected
>>> `void ACE_Ordered_MultiSet<T>::delete_nodes()':
>>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:1786: error:
> expected
>>> make[2]: *** [ServiceControllerBuild.lo] Error 1
>>> make[1]: *** [check-recursive] Error 1
>>> `/root/mapguide_install/mapguide-1.0.0/Common'
>>> make: *** [check-recursive] Error 1
>>> On 5/4/06, Walt Welton-Lair <walt.welton-lair at autodesk.com> wrote:
>>>> You need to show us more of the error trace...
>>>> Sent: Thursday, May 04, 2006 12:58 PM
>>>> Ups...
>>>> Now it fails somehwere else. Now I get this at the end of "make"
>>>> Any idea of what can this be?
>>>> Thanks.
>>>> On 5/4/06, Javier de la Torre <jatorre at gmail.com> wrote:
>>>>> Thanks all,
>>>>> I finally did a yum install libjpeg-devel and this installed the
>>>>> requiered libraries.
>>>>> Seems that I passed this step now :)
>>>>> It could be interesting to include in the documentation that the
>>>>> package that is needed is libjpeg-devel. Most people can then do
> a
>>>>> up2date or yum or apt-get to install it easily.
>>>>> Thanks again.
>>>>> Javier.
>>>>> On 5/4/06, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
>>>>>> You might have to specify --enable-shared as an input to the
>>>> configure
>>>>>> script.
>>>>>> Jason
>>>>>> Sent: Thursday, May 04, 2006 09:36
>>>>>> no, there is nothing there...
>>>>>> Am I installing the correct library? In the documentation it
>> says:
>>>>>> The libjpeg.so library is required. It is installed by default
>>> with
>>>> most
>>>>>> Linux distributions. If you do not have it, you can download
> the
>>>> source
>>>>>> from the Independent JPEG Group: www.ijg.org.
>>>>>> I downloaded from there:
>>>>>> http://www.ijg.org/files/jpegsrc.v6b.tar.gz
>>>>>> Now I am not sure...
>>>>>> JAvier.
>>>>>>> Did it put it under /usr/local/include by any chance?
>>>>>>> Sent: Thursday, May 04, 2006 12:23 PM
>>>>>>> Yes, I was logged as root.
>>>>>>> The file /usr/include/jpeglib.h does not exist.
>>>>>>> I downloaded the jpeg-6b and installed it but does not seems
>> to
>>>>>>> include this file. It copies others to usr/local/bin.
>>>>>>> Thanks.
>>>>>>>> Were you logged in as root when you did make install? Do
> you
>>>> have
>>>>>>>> jpeg installed (i.e. does /usr/include/jpeglib.h exist)?
>>>>>>>> Traian
>>>>>>>> Sent: Thursday, May 04, 2006 12:09 PM
>>>>>>>> Subject: [mapguide-users] Installing mapguide
>>>>>>>> Hi,
>>>>>>>> I am installing mapguide right now, but I am having some
>>>> problems
>>>>>>>> following the instructions on the PDF file.
>>>>>>>> I am trying to use all the default settings on an Intel
> with
>>> Red
>>>> Hat
>>>>>>> 9.
>>>>>>>> First I installed Apache, Tomcat and PHP (APT) using the
>>>> provided
>>>>>>>> package. Everything seems to be fine, the servers are
>>> available
>>>> and
>>>>>>>> everyhting worked fine.
>>>>>>>> Then I download the Mapguide server an Mapguider server
>>>> extensions
>>>>>>>> and I build the OEMcomponents. This also seems to compile
>>> fine.
>>>>>>>> IMake 1.0: Build Successful ........................
>>>>>>>> Done building OEM components .......................
>>>>>>>> Then I go and try to build and install the default
>>>> configuration:
>>>>>>>> aclocal I get this:
>>>>>>>> acinclude.m4:7: warning: underquoted definition of
>>>> MAP_HELP_STRING
>>>>>>>> run info '(automake)Extending aclocal'
>>>>>>>> or see
>>>> http://sources.redhat.com/automake/automake.html#Extending-aclocal
>>>>>>>> acinclude.m4:12: warning: underquoted definition of
>> MAP_SUBST
>>>>>>>> acinclude.m4:19: warning: underquoted definition of
>>>> MAP_FAST_OUTPUT
>>>>>>>> acinclude.m4:25: warning: underquoted definition of
>>>>>>> MAP_GEN_CONFIG_VARS
>>>>>>>> acinclude.m4:67: warning: underquoted definition of
>>>>>>>> MAP_GENERATE_MAKEFILES
>>>>>>>> acinclude.m4:74: warning: underquoted definition of
>> MAP_OUTPUT
>>>>>>>> acinclude.m4:83: warning: underquoted definition of
>>>>>>>> MAP_DEFINE_TYPE_RLIM_T
>>>>>>>> acinclude.m4:108: warning: underquoted definition of
>>>>>>>> MAP_SUBST_EXPANDED_ARG
>>>>>>>> acinclude.m4:115: warning: underquoted definition of
>>>>>>>> MAP_EXPORT_ARGUMENTS
>>>>>>>> libtoolize --force OK
>>>>>>>> automake --add-missing --copy OK
>>>>>>>> autoconf OK
>>>>>>>> ./configure OK
>>>>>>>> make OK
>>>>>>>> make check OK
>>>>>>>> make install get into troubles... After lot of messages I
>>> start
>>>>>>>> getting errors, this is the first one:
>>>>>>>> BOpcodeHandler.cpp:52:29: jpeglib.h: No such file or
>> directory
>>>>>>>> BOpcodeHandler.cpp:4970: error: field `jerr' has
> incomplete
>>> type
>>>>>>>> And I can not continue following the instructions :(
>>>>>>>> Anybody can help?
>>>>>>>> Thanks in advance.
>>>>>>>> Javier.
>>>>>>>> - To unsubscribe, e-mail:
>> users-unsubscribe at mapguide.osgeo.org
>>>>>>>> For additional commands, e-mail:
>> users-help at mapguide.osgeo.org
>>>>>>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>>>>> For additional commands, e-mail: users-help at mapguide.osgeo.org
Type: text/directory
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060505/9d9fcd16/JTorre.bin
More information about the Mapguide-users
