[mapguide-users] Installing mapguide
Traian Stanev traian.stanev at autodesk.com
Fri May 5 07:50:14 EDT 2006
Hmm, I don't think we build that library so it probably won't make a difference -- it's a PostgreSQL library and I'm not sure why it needs it... Could you run "ldd mgserver" and see what other libraries it is complaining about.
Traian
	-----Original Message-----
	From: Javier de la Torre [mailto:jatorre at gmail.com]
	Sent: Fri 5/5/2006 5:38 AM
	Cc:
	Subject: Re: [mapguide-users] Installing mapguide
	HI Trian,
	Today I tried to start from scratch again with the modifications that
	you gave me yesterday.
	I manage to make and make install this time, but I believe there were
	some errors (sorry I was not there when it executed and it was in a
	batch...).
	After doing the make / make install I tried to run mgserver.sh and
	this is what I got:
	[root at synthesys bin]# ./mgserver.sh
	/usr/local/mapguideopensource/server/bin /usr/local/
	./mgserver: error while loading shared libraries: libpq.so.4: cannot
	open shared object file: No such file or directory
	So this is probably because there were some errors in the building no?
	I will try the whole process again, but this time I will check if it
	fails somewhere in the process.
	Javier.
	On 04/05/2006, at 20:29, Traian Stanev wrote:
	> Looks like it's still complaining about ACE. Actually, ACE is supposed
	> to build as part of the build_oem.sh script. However, when you ran
	> build_oem.sh, ACE probably failed but did not exit the script (the
	> script in the released tar has that problem), so it was really broken
	> from the start. I don't know how much this has messed up the build
	> environment, so what I would do is to clean out the mapguide-1.0.0
	> directory completely, unzip the mapguide source again, then apply this
	> change *before* building anything.
	> Traian
	> Sent: Thursday, May 04, 2006 2:16 PM
	> I am loading lot of data in a PostGIS database so I am bored :)
	> I tried modifying this as you said and now I got a different error...
	> I could try to upgrade to gcc 4 but this is hard, this is a
	> dependencies nightmare...
	> For your info this is the error I get now:
	> de-1.0.0/Server/src/UnitTesting/.libs
	> /usr/bin/ld: cannot find -lACE
	> collect2: ld returned 1 exit status
	> make[3]: *** [mgserver] Error 1
	> make[3]: Leaving directory
	> `/root/mapguide_install/mapguide-1.0.0/Server/src/Core'
	> make[2]: *** [all-recursive] Error 1
	> make[2]: Leaving directory
	> `/root/mapguide_install/mapguide-1.0.0/Server/src'
	> make[1]: *** [all-recursive] Error 1
	> make[1]: Leaving directory
	> `/root/mapguide_install/mapguide-1.0.0/Server'
	> make: *** [all-recursive] Error 1
	> On 5/4/06, Traian Stanev <traian.stanev at autodesk.com> wrote:
	>> OK. This more or less matches what I was seeing -- I was trying to
	>> compile on gentoo with gcc 3.4 yesterday. It has to do with some
	>> templates in the ACE component. If I fix it I will send you the patch
	>> needed to the ACE global header.
	>> If you are feeling bored until then, you could try opening
	>> ./Oem/ACE/ACE_wrappers/ace/Global_Macros.h and replace the two
	>> occurences of (__GNUC__ >= 4) by (__GNUC__ >= 3). However, I am not
	> sure
	>> this is sufficient, since I haven't gotten through the whole ACE
	>> build
	>> successfully yet.
	>> Or you could try a different version of gcc but that's probably more
	>> painful if you don't have one installed already.
	>> Traian
	>> Sent: Thursday, May 04, 2006 1:35 PM
	>> gcc (GCC) 3.4.4 20050721 (Red Hat 3.4.4-2)
	>>> I think I have seen this problem before. What version of gcc are you
	>>> using?
	>>> Sent: Thursday, May 04, 2006 1:03 PM
	>>> Ok... I hope this is enough:
	>>> make[2]: Entering directory
	>>> `/root/mapguide_install/mapguide-1.0.0/Common/Service'
	>>> if /bin/sh ../../libtool --mode=compile --tag=CXX g++
	>>> -DPACKAGE_NAME=\"mapguide\" -DPACKAGE_TARNAME=\"mapguide\"
	>>> -DPACKAGE_VERSION=\"1.0.0\" -DPACKAGE_STRING=\"mapguide\ 1.0.0\"
	>>> -DPACKAGE_BUGREPORT=\"http://www.mapguide.osgeo.org\"
	>>> -DPACKAGE=\"mapguide\" -DVERSION=\"1.0.0\" -DSTDC_HEADERS=1
	>>> -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1
	>>> -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1
	>>> -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1
	>>> -DHAVE_DLFCN_H=1 -DSTDC_HEADERS=1 -DHAVE_UNISTD_H=1 -DHAVE_MATH_H=1
	>>> -DHAVE_NETDB_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_SYS_TYPES_H=1
	>>> -DHAVE_SYS_SOCKET_H=1 -DHAVE_GETHOSTBYNAME=1 -DHAVE_SOCKET=1
	>>> -DHAVE_HTONS=1 -DHAVE_CONNECT=1 -DHAVE_SHUTDOWN=1  -I. -I.
	>>> -IController -ICoordinateSystem -IData -IException -IGeometry
	>>> -IMapLayer -INet -IServices -ISystem -IUtil -I../Security
	>>> -I../MdfParser -I../MdfModel -I../../Oem/ACE/ACE_wrappers
	>>> -I../../Oem/geos-2.2.0/source/headers
	>>> -I../../Oem/dbxml-2.2.13/xerces-c-src/src -I../../Oem/proj-4.4.9/src
	>>> -I../../Oem/gdal-1.3.0/ogr -I../../Oem/gdal-1.3.0/port
	>>> -I../../Common/CoordinateSystem    -g -D_DEBUG -MT
	>>> ServiceControllerBuild.lo -MD -MP -MF
	>>> ".deps/ServiceControllerBuild.Tpo" -c -o ServiceControllerBuild.lo
	>>> `test -f 'Controller/ServiceControllerBuild.cpp' || echo
	>>> './'`Controller/ServiceControllerBuild.cpp; \
	>>> then mv -f ".deps/ServiceControllerBuild.Tpo"
	>>> ".deps/ServiceControllerBuild.Plo"; else rm -f
	>>> ".deps/ServiceControllerBuild.Tpo"; exit 1; fi
	>>>  g++ -DPACKAGE_NAME=\"mapguide\" -DPACKAGE_TARNAME=\"mapguide\"
	>>> -DPACKAGE_VERSION=\"1.0.0\" "-DPACKAGE_STRING=\"mapguide 1.0.0\""
	> -IController
	>>> -ICoordinateSystem -IData -IException -IGeometry -IMapLayer -INet
	>>> -IServices -ISystem -IUtil -I../Security -I../MdfParser
	> -I../MdfModel
	>>> -I../../Oem/ACE/ACE_wrappers -I../../Oem/geos-2.2.0/source/headers
	>>> -c Controller/ServiceControllerBuild.cpp  -fPIC -DPIC -o
	>>> .libs/ServiceControllerBuild.o
	>>> In file included from
	>>> ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.h:940,
	>>>                  from
	>> ../../Oem/ACE/ACE_wrappers/ace/Strategies_T.h:18,
	>>>                  from ../../Oem/ACE/ACE_wrappers/ace/Acceptor.h:24,
	>>>                  from ./AceCommon.h:56,
	>>>                  from Controller/Controller.cpp:18,
	>>>                  from Controller/ServiceControllerBuild.cpp:18:
	>>> ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp: In member
	>>> function `int ACE_Hash_Map_Manager_Ex<EXT_ID, INT_ID, HASH_KEY,
	>>> COMPARE_KEYS, ACE_LOCK>::close_i()':
	>>> ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp:158: error:
	>>> expected class-name before '(' token
	>>> COMPARE_KEYS, ACE_LOCK>::unbind_all_i()':
	>>> ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp:190: error:
	>>> COMPARE_KEYS, ACE_LOCK>::unbind_i(ACE_Hash_Map_Entry<EXT_ID,
	>>> INT_ID>*)':
	>>> ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp:289: error:
	>>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.h:286,
	>>>                  from
	>>> ../../Oem/ACE/ACE_wrappers/ace/Thread_Manager.h:26,
	>>>                  from
	>> ../../Oem/ACE/ACE_wrappers/ace/Strategies_T.h:25,
	>>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp: In member
	> function
	>>> `void ACE_Unbounded_Queue<T>::delete_nodes()':
	>>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp:133: error:
	>>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp: In destructor
	>>> `ACE_Unbounded_Queue<T>::~ACE_Unbounded_Queue()':
	>>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp:153: error:
	> function
	>>> `int ACE_Unbounded_Queue<T>::dequeue_head(T&)':
	>>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp:223: error:
	>>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.h:307,
	>>>                  from
	>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.h:34,
	>>>                  from
	> ../../Oem/ACE/ACE_wrappers/ace/Containers.h:69,
	>>>                  from
	>>> ../../Oem/ACE/ACE_wrappers/ace/Thread_Manager.h:27,
	>>>                  from
	>>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp: In member function
	>>> `void ACE_Unbounded_Set<T>::delete_nodes()':
	>>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp:107: error:
	> expected
	>>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp: In destructor
	>>> `ACE_Unbounded_Set<T>::~ACE_Unbounded_Set()':
	>>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp:126: error:
	> expected
	>>> `int ACE_Unbounded_Set<T>::remove(const T&)':
	>>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp:230: error:
	> expected
	>>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.h:1986,
	>>>                  from
	>>>                  from
	>>>                  from
	>>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp: In member function
	>>> `void ACE_Unbounded_Stack<T>::delete_all_nodes()':
	>>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:171: error: expected
	>>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp: In destructor
	>>> `ACE_Unbounded_Stack<T>::~ACE_Unbounded_Stack()':
	>>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:239: error: expected
	>>> `int ACE_Unbounded_Stack<T>::pop(T&)':
	>>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:275: error: expected
	>>> `int ACE_Unbounded_Stack<T>::remove(const T&)':
	>>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:334: error: expected
	>>> `int ACE_Ordered_MultiSet<T>::remove(const T&)':
	>>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:1582: error:
	> expected
	>>> `void ACE_Ordered_MultiSet<T>::delete_nodes()':
	>>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:1786: error:
	> expected
	>>> make[2]: *** [ServiceControllerBuild.lo] Error 1
	>>> make[1]: *** [check-recursive] Error 1
	>>> `/root/mapguide_install/mapguide-1.0.0/Common'
	>>> make: *** [check-recursive] Error 1
	>>> On 5/4/06, Walt Welton-Lair <walt.welton-lair at autodesk.com> wrote:
	>>>> You need to show us more of the error trace...
	>>>> Sent: Thursday, May 04, 2006 12:58 PM
	>>>> Ups...
	>>>> Now it fails somehwere else. Now I get this at the end of "make"
	>>>> Any idea of what can this be?
	>>>> Thanks.
	>>>> On 5/4/06, Javier de la Torre <jatorre at gmail.com> wrote:
	>>>>> Thanks all,
	>>>>> I finally did a yum install libjpeg-devel and this installed the
	>>>>> requiered libraries.
	>>>>> Seems that I passed this step now :)
	>>>>> It could be interesting to include in the documentation that the
	>>>>> package that is needed is libjpeg-devel. Most people can then do
	> a
	>>>>> up2date or yum or apt-get to install it easily.
	>>>>> Thanks again.
	>>>>> Javier.
	>>>>> On 5/4/06, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
	>>>>>> You might have to specify --enable-shared as an input to the
	>>>> configure
	>>>>>> script.
	>>>>>> Jason
	>>>>>> Sent: Thursday, May 04, 2006 09:36
	>>>>>> no, there is nothing there...
	>>>>>> Am I installing the correct library? In the documentation it
	>> says:
	>>>>>> The libjpeg.so library is required. It is installed by default
	>>> with
	>>>> most
	>>>>>> Linux distributions. If you do not have it, you can download
	> the
	>>>> source
	>>>>>> from the Independent JPEG Group: www.ijg.org.
	>>>>>> I downloaded from there:
	>>>>>> http://www.ijg.org/files/jpegsrc.v6b.tar.gz
	>>>>>> Now I am not sure...
	>>>>>> JAvier.
	>>>>>>> Did it put it under /usr/local/include by any chance?
	>>>>>>> Sent: Thursday, May 04, 2006 12:23 PM
	>>>>>>> Yes, I was logged as root.
	>>>>>>> The file /usr/include/jpeglib.h does not exist.
	>>>>>>> I downloaded the jpeg-6b and installed it but does not seems
	>> to
	>>>>>>> include this file. It copies others to usr/local/bin.
	>>>>>>> Thanks.
	>>>>>>>> Were you logged in as root when you did make install? Do
	> you
	>>>> have
	>>>>>>>> jpeg installed (i.e. does /usr/include/jpeglib.h exist)?
	>>>>>>>> Traian
	>>>>>>>> Sent: Thursday, May 04, 2006 12:09 PM
	>>>>>>>> Subject: [mapguide-users] Installing mapguide
	>>>>>>>> Hi,
	>>>>>>>> I am installing mapguide right now, but I am having some
	>>>> problems
	>>>>>>>> following the instructions on the PDF file.
	>>>>>>>> I am trying to use all the default settings on an Intel
	> with
	>>> Red
	>>>> Hat
	>>>>>>> 9.
	>>>>>>>> First I installed Apache, Tomcat and PHP (APT) using the
	>>>> provided
	>>>>>>>> package. Everything seems to be fine, the servers are
	>>> available
	>>>> and
	>>>>>>>> everyhting worked fine.
	>>>>>>>> Then I download the Mapguide server an Mapguider server
	>>>> extensions
	>>>>>>>> and I build the OEMcomponents. This also seems to compile
	>>> fine.
	>>>>>>>> IMake 1.0: Build Successful ........................
	>>>>>>>> Done building OEM components .......................
	>>>>>>>> Then I go and try to build and install the default
	>>>> configuration:
	>>>>>>>> aclocal    I get this:
	>>>>>>>> acinclude.m4:7: warning: underquoted definition of
	>>>> MAP_HELP_STRING
	>>>>>>>>   run info '(automake)Extending aclocal'
	>>>>>>>>   or see
	>>>> http://sources.redhat.com/automake/automake.html#Extending-aclocal
	>>>>>>>> acinclude.m4:12: warning: underquoted definition of
	>> MAP_SUBST
	>>>>>>>> acinclude.m4:19: warning: underquoted definition of
	>>>> MAP_FAST_OUTPUT
	>>>>>>>> acinclude.m4:25: warning: underquoted definition of
	>>>>>>> MAP_GEN_CONFIG_VARS
	>>>>>>>> acinclude.m4:67: warning: underquoted definition of
	>>>>>>>> MAP_GENERATE_MAKEFILES
	>>>>>>>> acinclude.m4:74: warning: underquoted definition of
	>> MAP_OUTPUT
	>>>>>>>> acinclude.m4:83: warning: underquoted definition of
	>>>>>>>> MAP_DEFINE_TYPE_RLIM_T
	>>>>>>>> acinclude.m4:108: warning: underquoted definition of
	>>>>>>>> MAP_SUBST_EXPANDED_ARG
	>>>>>>>> acinclude.m4:115: warning: underquoted definition of
	>>>>>>>> MAP_EXPORT_ARGUMENTS
	>>>>>>>> libtoolize --force OK
	>>>>>>>> automake --add-missing --copy   OK
	>>>>>>>> autoconf    OK
	>>>>>>>> ./configure   OK
	>>>>>>>> make OK
	>>>>>>>> make check OK
	>>>>>>>> make install  get into troubles... After lot of messages I
	>>> start
	>>>>>>>> getting errors, this is the first one:
	>>>>>>>> BOpcodeHandler.cpp:52:29: jpeglib.h: No such file or
	>> directory
	>>>>>>>> BOpcodeHandler.cpp:4970: error: field `jerr' has
	> incomplete
	>>> type
	>>>>>>>> And I can not continue following the instructions :(
	>>>>>>>> Anybody can help?
	>>>>>>>> Thanks in advance.
	>>>>>>>> Javier.
	>>>>>>>> - To unsubscribe, e-mail:
	>> users-unsubscribe at mapguide.osgeo.org
	>>>>>>>> For additional commands, e-mail:
	>> users-help at mapguide.osgeo.org
	>>>>>>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
	>>>>>> For additional commands, e-mail: users-help at mapguide.osgeo.org
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060505/35fc0495/attachment.bin
More information about the Mapguide-users mailing list
