[mapguide-users] Feature providers in Studio
Javier de la Torre jatorre at gmail.com
Sat May 6 09:41:37 EDT 2006
Hi Jason,
I don't know very much about Unix sorry, is it possible to share
the .so files between different Linux installations?
Javier.
On 05/05/2006, at 20:49, Jason Birch wrote:
> I'm not running MapGuide on Linux (tried to compile it on FreeBSD and
> was miserably unsuccessful), but if there are a number of Linux
> MapGuide
> users out there it might be useful to get .so versions of the
> additional
> FDO providers like Windows users have binary-only access to the .dll
> providers?
> Jason
> -----Original Message-----
> From: Traian Stanev [mailto:traian.stanev at autodesk.com]
> Sent: Friday, May 05, 2006 11:36
> To: users at mapguide.osgeo.org
> Subject: RE: [mapguide-users] Feature providers in Studio
> If you build the open source build, you will currently only get SHP
> and
> SDF support, no WMS or WFS yet.
> Not sure about the "Argument is null" problem, but you could be seeing
> the issue discussed in this thread:
> http://www.nabble.com/RE%3A-Studio-for-International-When--
> t1557663.html
> Traian
> From: Javier de la Torre [mailto:jatorre at gmail.com]
> Sent: Friday, May 05, 2006 10:01 AM
> Subject: [mapguide-users] Feature providers in Studio
> Hi,
> Now that I have mapguide server installed I would like to try it. I
> connected to the server using Studio from a Windows machine.
> I tried two things:
> 1) Configure a data connection to a WMS and a WFS servers. Wen I click
> on it I get a windows asking me to select a feature provider but the
> window is empty, there are no feature providers avaialble. Where is
> the
> problem here? Is ta problem with the installation of the FDO on the
> server or it has to do something with Studio?
> 2) When trying to load file-based data I select a bmp and georeference
> it but when I click on Load resources I get a "External component has
> throuhn an exception". If I select a shapefile it starts comunicating
> wth the server but at the end I get another laert window saying
> "Argument is null".
> Thanks.
> Javier.
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
Type: text/directory
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060506/27a81d98/JTorre.bin
More information about the Mapguide-users mailing list
