[mapguide-users] error providers
Andy Morsell amorsell at spatialgis.com
Mon May 8 19:14:27 EDT 2006
Your XML is not formed correctly.  Try this:
<?xml version="1.0" encoding="UTF-8" standalone="no" ?>
<FeatureProviderRegistry>
  <FeatureProvider>
    <Name>OSGeo.SHP.3.0</Name>
    <DisplayName>OSGeo FDO Provider for SHP </DisplayName>
    <Description>Read/write access to spatial and attribute data in an ESRI
SHP file. </Description>
    <IsManaged>False</IsManaged>
    <Version>3.0.0.0</Version>
    <FeatureDataObjectsVersion>3.0.0.0</FeatureDataObjectsVersion>
    <LibraryPath>c:\Program
Files\MapGuideOpenSource\Server\Bin\FDO\ShpProvider.dll</LibraryPath>
  </FeatureProvider>
  <FeatureProvider>
    <Name>OSGeo.SDF.3.0</Name>
    <DisplayName>OSGeo FDO Provider for SDF </DisplayName>
    <Description>Read/write access to Autodesk's spatial database format, a
file-based personal geodatabase that supports multiple features/attributes,
spatial indexing, and file-locking. </Description>
Files\MapGuideOpenSource\Server\Bin\FDO\SDFProvider.dll</LibraryPath>
  </FeatureProvider>
   <FeatureProvider>
    <Name>OSGeo.ODBC.3.0</Name>
    <DisplayName>OSGeo FDO Provider for ODBC</DisplayName>
    <Description>Read/write access to ODBC-based data store. Supports XYZ
point features.</Description>
    <LibraryPath>FdoOdbc.dll</LibraryPath>
  </FeatureProvider>
</FeatureProviderRegistry>
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
-----Original Message-----
[mailto:carpetascatastro at laplata.gov.ar]
Sent: Monday, May 08, 2006 4:02 PM
Subject: SPAM-LOW: RE: [mapguide-users] error providers
hi Jason
i downloaded and installed the files following the txt, but it doesn't work.
I don't understand why. The conection data window remaind empty in MapGuide
Studio.
What could it be.
providers.xml
  <FeatureProvider>
    <LibraryPath>C:\Archivos de
programa\MapGuideOpenSource\Server\Bin\FDO\ShpProvider.dll</LibraryPath>
  </FeatureProvider>
  <FeatureProvider>
programa\MapGuideOpenSource\Server\Bin\FDO\SDFProvider.dll</LibraryPath>
  </FeatureProvider>
  <FeatureProvider>
programa\MapGuideOpenSource\Server\Bin\FDO\FdoOdbc.dll</LibraryPath>
  </FeatureProvider>
thks.
Mensaje citado por Jason Birch <Jason.Birch at nanaimo.ca>:
> Hi Oscar,
> So, you can add an SHP or SDF data source, but not establish a data
> connection?  This is probably because out of the box there are no
> providers for basic data connections.
> Because you're on Windows, you can download previews of some (mix of
> proprietary and OS) here:
> https://mapguide.osgeo.org/servlets/ProjectDocumentList?folderID=35
> <https://mapguide.osgeo.org/servlets/ProjectDocumentList?folderID=35&e
> xp andFolder=35&folderID=4> &expandFolder=35&folderID=4
> There are instructions for integrating these providers into server in
> each zipfile.  Careful, because only the OSGeo providers will be
> distributed in source form, the rest will be part of Autodesk MapGuide
> Enterprise.
> Jason
>   _____
> From: carpetascatastro at laplata.gov.ar
> Sent: Mon 2006-05-08 1:38 PM
> Subject: [mapguide-users] error providers
> My name is oscar im fron to argentina, im work whith gis system.
> Sorry for my english, i have problems install mapgide open source in
> windows system + apache, my problem is the conection providers the
> list is empty.
> im check the paths in the .ini but not work my S.O. is in spanish is
> it afect??
> Si alguien habla español podemos armar un foro en español??
> very thanks
> oscar
> This message was sent using IMP, the Internet Messaging Program.
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
