Integrating remote layers into existing repository
kalpesh kalpesh at pie-solution.com
Fri May 12 02:09:20 EDT 2006
Would it be possible to integrate a shp file which is on a client's machine
in the repository which is hosted on a server.
E.g. There is a server running MGOS and having a respository. This server
has an app which shows the map from the repository and allows many other
functionalities to the user. Now there are some clients who have their own
set of .shp files on their local hard disk.
Is it possible to integrate these layers at run time and display them as
part of the map for that user only ?
- Kalpesh
View this message in context: http://www.nabble.com/Integrating-remote-layers-into-existing-repository-t1605641.html#a4353417
Sent from the OSGeo MapGuide forum at Nabble.com.
More information about the Mapguide-users mailing list
